Question about Toshiba Satellite Computers & Internet
M70-337 cooling fan removal
Cooling fan broke
  • Toshiba Master
  • 16,974 Answers
The best site for this is here: http://www.irisvista.com/tech/
Posted on Jan 16, 2013
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
How to change a coolant fan for a 2001 impala
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling fan.
  3. Raise and support the vehicle. Refer to Vehicle Lifting.
  4. Remove the transmission oil cooler lines from the retainers at the bottom of the cooling fan shroud.
  5. Remove the lower fan shroud push pin retainers.
  6. Lower the vehicle.
  7. Remove the right and the left engine mount struts.
  8. Remove the left front fender upper diagonal brace.
  9. Remove the radiator inlet hose from the radiator.
  10. Remove the air cleaner assembly.
  11. If equipped remove the cooling fan heat shields.
  12. Disconnect the cooling fan shroud electrical connectors.
  13. Remove the cooling fan shroud bolts.
  14. Disengage the cooling fan shroud clip from the top of the radiator.
  15. Remove the cooling fan shroud.
Aug 25, 2014 | 2001 Chevrolet Impala
The bottom part of the cooling fan has broke and i cant keep the fan in place how do i solve this problem
Once a fan blade is broken the unit will no longer be in balance. The cost is only five dollars, so replace it.
Apr 06, 2014 | Compaq Presario SR1503WM Case Fan |...
Fan for cooling system very loud. but car isnt running hot
open the hood and make sure it hasnt broke the shroud that the fan sits in or broke a fin on the fan. if not the bearings in the fan may be worn and the fan needs replacing. hope this helps
Jan 31, 2011 | 2004 Lincoln LS
I have a 1999 chevy cavalier and the cooling fan will not start
CHECK COOLING FAN FUSE AND RELAY.IF BOTH GOOD SCAN CAR TO CHECK COOLANT TEMPERATURE SENSOR FAULT CODE.THE PCM AND COOLANT TEMP. SENSOR IS WHAT CAUSE FAN TO RUN AT CERTAIN TEMPERATURE.IF ALL IS GOOD.HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN REPLACE FAN MOTOR.IF FAN RUNS YOU HAVE SHORT OR BROKE WIRE IN THE COOLING FAN ELECTRICAL CONNECTOR.
May 06, 2010 | 1999 Chevrolet Cavalier
If the cooling fan on my Vizio RP56 stops working, will it cause my screen to go blank, seems like bulb will not work if cooling fan is broke.
The fans are all monitored by the Micro. When one goes down, especially the lamp fan, they will not fire. If the fan is bad, replace it. If it's not I would call a service company.
Nov 03, 2009 | V, Inc. VIZIO RP56 Rear Projection...
One of the blades broke off the cooling fan
Go to a decent autowrecker, they have a complete or help you out.
Mar 21, 2009 | 1992 Lexus Ls 400
Honda Accord 1995 temp sensor
maybe this will hel57436774p you
Feb 17, 2009 | 1995 Honda Accord
Internal cooling fan
Not aware of any cooling fan in a TV system
Nov 04, 2017 | Panasonic PT-50LC13 50" Rear Projection...
Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes Cool Breezes carries parts for old fans that Hunter no longer carries parts for COOL BREEZES 1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
Sep 18, 2008 | Dryers
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
