Power on Board Bright light won't hold charge
My Power on Board - Bright Bar won't hold a charge. Where can I purchase a new battery?
  • 7,627 Answers
On what kind of PC Laptop?
Posted on Jan 16, 2013
cheap to fix
  • 404 Answers
SOURCE: toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Posted on Mar 03, 2009
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Posted on Sep 15, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
SOURCE: Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
Posted on May 15, 2012
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
COMPAQ V2030US POWER ON WON'T START
if there are no Power light,you battery might be broken or your power button is broken,i suggest you to charge your battery or take it to notebook center (if charging still failed,it might be the button)
Aug 27, 2012 | HP Compaq Presario V2000 Notebook
2004 ford expedition charging system failed?
Sounds like battery not holding charge. Or a light staying on, boot or glovebox? Most likely battery tho.
Nov 16, 2011 | 2004 Ford Expedition
May 12, 2011 | Computers & Internet
My camera wont charge in the tray or the charge light won't come on. Camera keeps saying low battery.
My guess is that with the age of the battery it isn't able to hold a charge anymore which means you'll need to purchase a new battery. Your best bet for that will be to go through Sony or the website Dr. Battery.
May 11, 2011 | Sony DCR-HC52E Mini DV Camcorder
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
I have a unit that is about 4 years old and appears to NOT hold a charge. I know to only charge for 3 hrs max but want to be sure my problem is the $75.00 battery before I purchase one. What is your...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have the Vector Power On Board Bright Bar model WLB26MCP and I need the recharging device. How can I get one. Thank you, fnnsmith@aol.com
You can purchase one from Black and Decker, Vector was purchased from them in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?r=No%20%Results
Oct 05, 2009 | Vector Power On Board High Intensity...
New bright 19.2v nicd battery problem
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
