Question about Fossil JR1156 Watch
What do the buttons and dials do? - Fossil JR1156 Watch
  • Fossil Master
  • 18,394 Answers
How do I set the time on my gold watch that has three buttons
As your watch has 3 buttons I am assuming that it has the main dial and 2 sub dials maybee to show the date. The centre button should pull out (DO IT GENTLY) and either will stop or click ,you should then rotate it to set the time, when done push it back in to start the watch running.
The 2 outer buttons probably work by pushing them in a click at a time to set there respective dials.
Oct 02, 2017 | The Watches
Accutime watch in roman numerals, has 3 small circles on inside of the face of the watch . i don't kno what they are for or how to run them?
I'm not familiar with Accutime watches, but it may be that the 3 sub-dials are there just for decoration.
If they're not, then the upper and lower buttons on the right will control the hands on the sub-dials.
Check the following:-
Is there any movement in the buttons when you press them, or do they feel solid as if they are part of the casing?
Do the hands on the sub-dials look as though they are slightly raised or do they look as though they are glued on?
Does pressing either of the buttons cause any of the hands to move?
If pressing the buttons has no effect at all then you can be sure that the sub-dials are decorative only.
If the sub-dial hands do move when you try the above suggestions, then get back in touch for further instructions.
Oct 06, 2016 | The Watches
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
How can we set the chronograph dial
From time to time, chrono sub dial hands will be off. Solution is rather simple, pull out your crown and push either top and bottom button, each button will set certain hands on sub dials. This applies to both positions of crown (depending on complication & number of sub dials).
Apr 11, 2012 | Watches
I have model fs-2919 would like to know what the other dials are for i dont have the booklet thanks for your help
The three small dials on this watch are all part of a "stopwatch" system. The small dial at the 12 o'clock is for tenths of a second( each half circle completed is one second or 1 whole rotation equals 2 seconds.) the small dial at the 6 o'clock counts a full 60 seconds for each revolution, and the dial at the 9 o'clock counts minutes(one full circle equaling an hour.) when the stop watch is started the 12 o'clock and 6 o'clock dials will start at the same time. you will notice that every half turn on the top dial equals one "tick" on the bottom dial. After the first minute of timing the top dial will stop ticking as it is for more precise timing of things that take less than 1 minute. each full rotation of the bottom dial will then equate to one "tick" of the 9 o'clock dial. hence the three dials counting tenths of a second, seconds and minutes. the setting of these dials is fairly easy once you understand the purpose. on the side of the watch there are two buttons(one top and one bottom) with a setting wheel in the center. When in use the top button starts and stops the stopwatch and the bottom button resets the counters. To set the watch simply pull the center wheel away from the watch all the way(2 clicks) set your minute hand and hour hand and then tap the bottom button repeatedly until the small dials all line up straight up. once that is done push the center wheel button halfway into the watch or one click to set the date. then simply push the wheel the rest of the way in and voila!!! hope this answers some questions
Apr 05, 2011 | Fossil FS2919 Wrist Watch
My analog stopwatch needle at 11 instead of 12o'clock
The procedure for the Classima Chronograph watch is different. You need to pull the dial all the way out, press on both buttons and hold for 5 sec, until the seconds dial makes a full cirlce (signalling that the chronograph is now ready for manual reset, then press the button on 2 o'clock until the seconds dial reaches the 12 o'clock position, then press button at 4 o'clock, to transfer control to the 1/10 dial, press button at 2 o'clock again a number of times until it resets to 0, then press 2 o'clock dial again to transfer control to the little hours dial, and press 4 o'clock button number of times until you reset this one to 0 too. Now just push back the dial crown to original position to close the operation. Viola
Dec 22, 2009 | Watches
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
HOW TO WORK THE SUB DIALS
This is an Architect Chronograph. To start the chronograph press the top start button. To stop it press it again. To reset it press the reset or bottom button. The sub dials are minutes, hours, and seconds.
May 03, 2009 | Fossil Arkitekt watch
Vivani watch has multiple dials and buttons but no response
Yeah I have the same kind of watch. The three small dials are ornamental and nothing more (this is obvious because their denominations are 60, 60, and 24, instead of something useful like 1-12 month, 1-31 for date, and 7 days of week). The extra two spring buttons are probably the same... nothing but ornamental. You could verify this by taking the back off the watch and seeing for yourself that they probably press nothing at all. Are simply there for maybe some other design where the case is uses,to illuminate the dial or other thing not on the watch. Vivani watches seem to be simple watches that are very ornamental and pretty (i.e., dress watches on the cheap) but completely lacking in features at all.).
Apr 16, 2009 | Watches
Using the stop watch feature
Dennis,
"Chronograph" is watch terminology for 'stop-watch'.
There are 3 small dials on the watch.  The main dial has a minute hand and an hour hand.  The big second hand on the main dial is not for the main time of the watch.  It is for measuring seconds for the stopwatch.
The 2 small dials at 10 o'clock and 2 o'clock will give you minutes and 1/10 of a seconds.
There are 2 buttons on the side of the watch. Top Button:  Start/Stop Bottom Button: Reset
To set the chronograph to its default position, you would pull out the stem to the first position and push the buttons.  Also, pull the stem out further to the 2nd position and push the buttons.
Jan 13, 2009 | Swatch Chronograph Wach SVCK4035G Watch...
Fossil JR1156 Watch Logo
115 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
