Question about Poulan Garden
My new model pp5020av will not start
After 3 tanks of gas it will not fire up
  • 169 Answers
Its most likely flooded......put choke off and pull it till it starts....if not ot could be a coil....most likely under warranty if its a coil
Posted on Jan 16, 2013
  • Dick Pascucci Jan 17, 2013
    i dont think its flooded! pulled plug dried it 3 times still will not fire checked i have spark
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
#pp5020av pull cord
The length of the Starter pull cord is 40"
It can be purchased at www.ereplacement parts.com
I have no affiliation with this site or company. They simply have great prices and also list exploded views of this saw and others.
http://www.ereplacementparts.com/poulan-pp5020av-stroke-gas-chainsaw-parts-c-16962_17147_162366.html
Aug 04, 2014 | Poulan Pro Pp5020av Gas Chain Saw 20" 50cc...
What is the replacemnet cord size for my #pp5020av
www.ereplacementparts.com lists the part as Kit Rope 40" (Type 4.5)
Part Number: 530069919 Priced at $2.84 and if you need a new handle, it's only $2.73
The link is below.
Aug 04, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
328i won't start. Turns over but doesn't fire.
Sounds like your fuel pump has stopped working get it checked out.
Dec 27, 2009 | 2008 BMW 3 Series
Starts and runs until it gets hot.
Hello:
Your Problem can be Caused by Several Possible Items.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
>>Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Sep 13, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a cub cadet model 3 1042 it starts but
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Dies after 10-15 min of use
Hello barcomb31:
Good Luck
Respectfully
jbridger (John)
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
R1 2000 starting problems
Sound like a fuel problem.drain gas from gas tank and carb.you may have to take off the carb and clean it .If it is fuel injection they will have to be clean to.This will happon when a bike set that long
Feb 21, 2009 | 2000 Yamaha YZF-R1
Garden Logo
171 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
