My Fagor washing machine wont empty
My machine keeps comming up with the fault code F02. whats wrong with it and what can I do? its driving me crazy as Ive been two weeks without it working had a new filter as the other broke and now its doing this.
  • 1 more comment
  • charliepenma Jan 24, 2009
    The model number is 2FU-311
    thank you
  • onthethejob1
    onthethejob1 May 11, 2010
    imsorry but this model number does not run...this is not an american ..unit,,????
  • onthethejob1
    fagor???please send model number
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My Cda washing machine is showing f02 fault code
CDA WASHING MACHINE CI931IN SHOWS FAULT F02 ..not sure if this is your model..when you go to this page just scroll down the page and you will see what you need to read.do not fill any thing in.
Nov 20, 2016 | CDA Washing Machines
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
F02 fault cleaned out the filter but still wont work
Possible that the inlet flow is low, Clean the inlet filter, check the inlet flow. Check the drain filter and if this was clogged, then the chances are that the valve must be removed and cleaned.
Sep 04, 2014 | Fagor Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Showing f02
Error Code F02 = Motor jammed or tachogenerator detached
Check the motor hasn't jammed up somehow, or that the small tacho coil on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running. This fault is not caused by worn carbon brushes because on these washing machines, an open circuit on the motor causes the washing machine to do nothing at all. It would not fill, or empty (as well as the motor wouldn't run) although the indicator lights would work. These washing machines do not produce an error code for open circuits in the motor.
Hope this helps (remember to rate and comment this answer)
Apr 01, 2011 | Washing Machines
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
F02 error code on Fagor FU6146IT
attempted to look up your washing machine on www.repairclinic.com they don't list Fagor, but you can go to that site and do some research. That website lists error codes for countless appliances as well as troubleshooting guides for the codes. Good luck
Jan 07, 2010 | Washing Machines
This is your lucky day my friend. Your drain hose anywhere from right underneath the drum to the filter is clogged. Clear out the surprising amount of lint and you'll be just fine. :-)
Nov 21, 2009 | Washing Machines
F02
you might try here fill in your model and search for user manual download
http://www.fagor.com/mun/_bin/ingl/downloads2.php
Mar 28, 2009 | Washing Machines
Washing Machines Logo
912 people viewed this question
Top Washing Machines Experts
