Question about Dryers
GTWN4950L0WS ge washing machine Where is the fuse link or thermal fuse located? It will not start.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
With Maytags its in the top where the timer is ,a little glass fuse,i usually just jump it out ,you do what you want
Posted on Jan 16, 2013
2 Suggested Answers
SOURCE: thermal fuse location
where located fuse
Posted on Sep 17, 2008
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
I have a GE washer Model GTWN4950L0WS, was washing clothes and power went out and came back on several times. Now washer has water standing in it and non of the cycles will work. I have tried unplugging to...
You can drain it by using a wet and dry vacuum on the drain hose. Or lower the hose to the point that it lets water out with gravity. If you don't have any lights or anything on the machine then you need a meter to check the power connections.
Aug 10, 2014 | Washing Machines
Blown fuse
There is a thermal fuse in the circuit between the dryer drive motor, and the dryer timer motor (control). It's physically located near the blower assembly. Whirlpool 33001762 Thermal Fuse AppliancePartsPros com There is a picture of it at this link. That's the only "fuse" I could find in the parts manual I have for the MLG2000AWW.
Feb 10, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
GE DPSE810EG won't start
You will need to check and see if the dryer has a bad thermal fuse on it. If so, it will cause the dryer not to start.
The thermal fuse should read closed for continuity. The thermostat is number 507 on this diagram. It is located on the top of the heating element housing.
Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE Profile 7.0 cu. ft. Electric Super...
GTWN4950L0WS
1) is plugged in in receptacle?
2) test the fuse if is blown from your hourse
3) reset the circuit breaker from your hourse
4)test lid switch for open or defective , use the VOM see the diagram attached.
God bless you
Sep 19, 2012 | Kenmore Oasis HE 27082 Top Load Washer
Dryer runs but does not got hot, therefore does not properly dry clothes. I checked the heater element and it is good. Any suggestions?
The Most common problem is a bad thermal fuse.
1 the thermal fuses are located in the cabinet of the dryer under the drum
they can also be located on the front of the blower wheel housing. on the back wall of the dryer or along the heating element can.
2. some kenmore, whirlpool machines have these fuses located in the rear of the machine.especially when the lint filter is located in the top of the dryer.
3. the heating element can also be bad.
4. if you have an ohm meter you can check the continuity of the thermal fuses,as well as the heating element.if there is no continuity on any of the above mentioned parts. Replace the faulty parts.
Jan 10, 2011 | GE WSM2420T Top Load Stacked Washer /...
Wont start when start button pushed
Hi, Check the thermal fuse... that is fairly common..
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 17, 2010 | GE Profile Prodigy WPSE4200A
Washer wont start
your vent is prob. stoped up so the dryer got to hot a blew a thermal fuse..it is located at the top of the element housing
Apr 12, 2007 | GE WSM2700W Unitized Spacemaker Washer and...
Dryers Logo
148 people viewed this question
Top Dryers Experts
