Question about AT&T Blackberry Curve 8300 Smartphone
My blackbery curve keeps going into standby
Overnight my blackberry curve went into standby it wouldnt turn back on
i took the battery out it eventually turned on but it wont let me do anything when someone rang me it woudnt let me answer non of the keys i pressed worked it told me i had a missed call and messages but when i press the key nothing happened and then it went into standby again
  • hottbuggn Jan 27, 2009
    Yes I am having the same problem, can't anyone help ASAP please!
    Brigadier General:
  • 7,752 Answers
Try this method
When your device fails to start, it show one of these symptoms:
1. Totally dead.
2. Trying to restart, LED activity only.
3. Failed to start, a white screen with an error message.
__________________________________________________ ________
1. Physical damage, water is the worst enemy of delicate electronic device. Try drying it with a desiccant and replacing the battery. If there is no activity, you can still try the last ditch technique, nothing to loose anyway.
2. Your device is not able to start, something has gone wrong and the OS is corrupt.
3. Geeks call this an "Uncaught exception error". That is a polite way of saying, the last thread has terminated, the OS has halted because it is corrupt.
In many cases, the Application Loader can be used from Desktop Manager or Windows.
If that fails to connect, there is one final solution. Go Old Skool ...
The good news, starting from scratch, you will be back in service in a couple of hours. my blackbery curve keeps going into standby - biggrin.gif
Note: Windows 7 beta is not compatible with these instructions.
1. ...
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Posted on Feb 04, 2010
How to install a free downloaded themes for my blackbery
Hello Elm,
Free downloadable themes for Blackberry RIM Curve 8900 :
http://blackberryrocks.com/2009/02/12/free-themes-blackberry-curve-8900-cool-blackberry-themes/
Oct 13, 2011 | RIM Blackberry Curve 8900
At&t blackbery curve 8300 won't turn on and keeps on blinking red light
That could be dead battery meaning replace it.
Could mean dead OS where you need to reinstall it
Sep 26, 2011 | AT&T Blackberry Curve 8300 Smartphone
Took out the battery and phone wouldnt turn on. there s only a red blinking light
You need to connect the phone to your pc without the battery install and open up your blackberry desktop manager.....go to application loader and update the phone's OS , this should correct the problem :)
Aug 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry curve 8330 - mute key quit working
This is an odd one. I have worked with Blackberys for many years not come across this.
How long do you take the battery out? Keep the battery out for at least 2-3 minutes.
Also, is the mute key button broken inwards?
Does the Battery Charge still when you plug it to the Mains paower socket?
If the battery is fine then I would suspect the Device having some fault.
Let me know how it goes,
Thanks.
Mar 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
When i turn on my blackberry i see the hourglass for about 10 seconds and then it turns off. It keeps repeating this cycle but i never turns on. What should i do?
This issue usually is caused by Battery terminal or Bad USB port which requires opening the phone for repair. However you blackberies need to be flashed with the latest software first just to make sure that its not a software failure.
You can do the software flash using the blackberry desktop. You need to download the appropriate software according to your phone and install it to your computer first. Then using the app loader on the blackberry desktop, it will direct you to install the new software. Please let me know if you need more assistance
Mar 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Problem downloading Blackbery messenger for 8300
go to www.blacberry.com then update your OS (messenger included)
Mar 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve is resetting itself for no reason
I had the same problem with mine. It started reseting when I tried to connect wi-fi to my wireless network at home, as soon as I entered my security code. To fix this problem I had to turn off power on blackberry (If you hold power button of blackbery it will power off when it gets to desktop screen let it go and your bb will power off). then turn power off on your wireless router and your bb should turn on. Go to manage connections and turn wi-fi off. Apparently it is a bug in the os. mine works great.
Dec 12, 2008 | RIM BlackBerry Curve 8310 Smartphone
Blackberry will not turn on
have you tried pressing the standby button on the very top left hand side of the device
Sep 15, 2008 | RIM BlackBerry Curve 8310 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
560 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
