Question about Panasonic KX-TG2431 Cordless Phone
Panasonic cordless phone KXTG2431 discharge too fast
Hi
My telephone discharge completely after 12 hours in stanby mode, even after changing the batterie with a new one.
When I bought the new batterie, it took 48 hours to recharge completly, but like I said before, it just took 12 hours in stanby mode to die.
Is someone got any idea what component failed ? It could be a leaking diode but I do not have the schematic of the phone.
Thanks
Ricky0
  • Ricky0 Feb 23, 2009
    Hi.
    Your solution imply that the batttery was in fault (i.e. memory effect) and a full discharge and a slow recharge will reset the battery.
    However, NiMH does not have memory effect like NiCd.
    Also, I did change the battery with a new one. the problem was exactly the same. So, it is either the charger or the telephone. After changing the base (i got 2 phones), the problem follow the phone, not the base charging the phone.
    Anyway, I threw the phone to garbage. I still have the other one working.
    Ricky0
Hi,i'm hamed from IRAN
I have a panasonic phone model:KX-TC1282JXB and it has a problem: Discharge very soon the battery and recharge hardly or phone can't recharge it !?
<< My dicovery solution worcking 100% >>
Steps:
1-remove battery from remote-handel.
2-create two wires.
3-the jumper of battery must have two wires(red & black).
4-contact you're created wires to jumper of battery.
5-be careful! now you must connect two wires to base of phone where the remote-handel settle there at below be exist two slots "phase+" and "null-".
note: when you connect correct,the green lamp must be shining.
Recommend: (near slot by base keyboard connect black wire) and (other slot connect red wire).
6-connected battery must be take between 45min - 75min.
note: the battery to be warm don't worry, just control to pass time.
7-then release base and battery form two wires.
8-connect the battery to remote-handel,you can see it has charged for minimum amount (one-unit)
9-finally connect remote-handel to the base for give full charge,it take between 8h - 12h.
you can ask me you're question(s) : hamedsbt@yahoo.com
bye :-)
Posted on Feb 22, 2009
Where can I get a telephone manual for Panasonic KX-TG2205W
Hope this helps
Panasonic Telephone KX-TG2205W User Guide ' ManualsOnline.com
www.manualsonline.com > ... > Communications Panasonic > Panasonic Telephone
2.4GHz Digital Cordless Phone. Model No. KX-TG2205W. Pulse-or-tone dialing capability. OperatingInstructions. Charge the battery for about 15 hours before ...
Apr 02, 2017 | Panasonic Lands Phones
I need a user manual for this phone.
Search Results
    Free Panasonic Telephone User Manuals ' ManualsOnline ...
    phone.manualsonline.com > ... > Panasonic > Communications Panasonic
    Products 1 - 50 of 923 - Panasonic Global VoIP Telephone User's Manual BB-GT1500 BB-GT1540. Pages: 0 ... Panasonic Cordless Telephone User Manual.
    Free Panasonic Cordless Telephone User Manuals ...
    Products 1 - 50 of 259 - Panasonic Cordless Telephone KX-TC1000B. PanasonicCordless Telephone User Manual. Pages: 0 Saves: 0. See Prices
    Panasonic - Support
    help.panasonic.ca/
    Area / Country. © 2015 Panasonic Canada Inc. All rights reserved. About Panasonic · Privacy Policy · Terms of Use · Sitemap · Facebook · Youtube · LinkedIn.
    [PDF]Operating Instructions - Support - Panasonic
Jan 28, 2016 | Lands Phones
How can i put my phones KX TGA641C in French?
PDF]Operating Instructions - Panasonic Canada
https://panasonic.ca/PCS/.../KXTG6411-12-13-14-OI-Eng.pdf
Panasonicappropriate service offered by your service provider/telephone company. .... Feature.KX-TGA641C. KX-TGA740C. KX-TGA840C. Handset. Display colour/ size ..... "Fran?ais" as the display language. .... This feature allows you to put an outside.
[PDF]Installation Manual - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-tga641_im.pdf
PanasonicNov 19, 2008 - Charge the batteries for about 7 hours before initial use. Additional Digital Cordless Handset. Model No. KX-TGA641. Installation Manual.Missing: french
Dec 17, 2015 | Lands Phones
Panasonic kx tga931t
Remove the telephone from it's base; then remove the battery cover; disconnect the battery.
With the battery disconnected, press the power button on the telephone to fully discharge it.
Wait 2 minutes to be certain the telephone is fully discharged, then reconnect the battery and replace it on the base.
This will get you to the point that you can go out and purchase a replacement battery for these panasonic cordless telephones.
Feb 03, 2014 | Lands Phones
How do i change the battery in panasonic es-rt51 electric shaver
Panasonic ES-RT51 battery problems?
If your razor battery runs down after only a few shaves e.g jumps from 60% to zero Let the razor completely discharge by leaving it switched on until the blades stop moving completely. (This can take over 24 hours so be patient) When they are stop moving recharge the battery and you will find the battery will charge and discharge just like new!
(This may take a couple of discharge cycles). Only charge the battery when it is flat after this and the problem SHOULD not reoccur.
Terence Saunders
Jan 01, 2014 | Electronics - Others
How do i turn off eco mode in panasonic cordless
You cannot turn off the ECO mode manually.
Intelligent ECO mode (select models)
Power consumption is automatically reduced when the handset is close to the base unit for extended talk time. Battery life on Talk is up to 13 hours when in ECO mode.
https://panasonic.ca/english/telecom/telephones/features.asp#eco
Jun 25, 2012 | Panasonic KX TG4021 Cordless Phone
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
My Cell phone battery get discharged very soon while talking on the phone for more than 10-15 min or listening to music for more than 2 min i even changed ma battery a number of time but that problem...
Your battery is just about dead. Time to replace it. The battery life depends on how you use it and how you charge it. You should typically be seeing at least 4-6 hours of talking and a lot more when not in use on a new fresh battery.Get a new battery and allow it to fully charge for 12-16 hours before using.
If you are a heavy user expect to replace the battery once a year.
Jan 20, 2011 | Health & Beauty
Panasonic KX-TG2431 Cordless Phone Logo
312 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
