Question about Philips CDR770 CD Recorder
No power help needed i have checked internal and external fuse but still no life in it any suggestions
  • 4 more comments
  • james kennedy Oct 23, 2007
    i replaced psu  board  all is fine
    replaced psu board and all is fine found supplyer on ebay by posting a want it now  thanks james
  • james kennedy Dec 08, 2007
    i confirm it was you many thanks again
  • james kennedy Jan 30, 2008
    there is two one obviously is in the plug and the other is on the psu board its self i am told that these boards dont like heavy impact and as a result fail i tryed replacing rectifier diodes and some resistors but in the end opted for replceing the whole board and it worked fine
  • taratula May 04, 2008
    No Power but fuse OK
  • taratula May 06, 2008
    Which diodes or PSU board and wheren can I find them
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Where do I find the interior and exterior fuses
I too have a power problem
Thanks, UCLAbear@aol.com
Posted on Jan 28, 2008
  • Nan
    Nan Jan 28, 2008
    Hi JamesKennedy OR anybody that has this info.....
    Can you please tell me where I can find the external and internal fuse on the PHILLIPS CDR770
    And where to find a schematic for this unit :-]
    I am hoping that an easy fix for no power would be the fuse and of course the users manual does not go into the unit, just the exterior.
    Thank YOU in advance for your time and info :-)
    Kre8ful
  • 112 Answers
Me! Small world! Fluffcat1.
Posted on Dec 07, 2007
How do I reset a technics sa-gx350 receiver unit
Don't know that you can actually reset this unit like the new digital receivers. It does have protection circuitry that will shut the unit down in case speaker wires are shorted or if speaker impedance is less than the indicated rated impedance of the amp. do the following:
1. Turn off power and unplug from wall.
2. Check all connections and correct if needed.
3. Turn back on after 1-2 minutes.
If unit is still in protect mode you may want to unplug everything from the unit and then power back up to see if the problem is internal or external. If it powers up correctly then the problem is external. Power back down and plug in one external item at a time and power back up between connecting each item to see which item causes the receiver to go into protection mode.
If problem seems to be internal I'd recommend taking to an electronics repair shop if you aren't comfortable with taking apart to check fuses, terminations, etc. There may be a 5-amp fuse in the power plug head also.
Oct 21, 2013 | Audio Players & Recorders
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
Light not coming on
Is there power at the outlet socket? Check the power cord from the outlet socket to the amp.If the power indication light on the amp does come on the you will need to check the internal fuses.Some models have an external fuse located on the back panel
Apr 09, 2013 | Dual XPE2700 400w 2ch bridgeable amp
Eton 1550 UPS not working (No power and tottaly off LED)
Check fuses.external and internal fuses.
almost all the times there is a circuit breaker outside.
Inside there is a fuse .replace
Aug 28, 2012 | Eaton Evolution 1550 UPS 11 kW 1550 VA...
I have kenwood excelon ddx 7015 unit powers up but says a cord is not pluged in. Wanted to know if this unit has a internal or external brain box and if it has an external brainbox how do i find one
I have a DDX7015, and can tell you that the unit is completely self-contained. You can get a kds-p901 external 5.1 processing unit that deactivates the on-board processing brain; the 901 connects via fiber optic.
It sounds like your constant power (yellow) is not energizing. You can test that pretty easy - you should be able to hit the eject button with the car turned off, and the faceplate should lower.
Try pulling the unit out and checking the in-line fuses and the wires - you may find that the wires got crushed during installation. To test functionality, you can try twisting both red and yellow together, and connecting it directly to the battery. You may find that your 'constant power' in your dash is unable to supply the current this head unit needs (7-10A, if I remember correctly). If that's the case, you may need to run a dedicated wire out to the battery for the yellow. Make sure you put a fuse close to the battery. The fuse is not to protect the head unit, but to keep the wire from burning up in the event it gets shorted, so the fuse can be 20A or so (the head unit should have its own fuse). I hope your head unit comes to life - I've had 6 years of great service from mine, and it plays mp3s and wmas directly off of a data DVD, and works great with the KNA-DV4100 navigation system.
Sep 04, 2010 | Car Audio & Video
Suddenly power goes off. will not restart,
If there is no external fuse at the back panel, then there must be an internal fuse. I assume you tried another outlet in your home.
Nov 30, 2009 | Mitsubishi M-VR700
My ups beep continuosly and then shuts off.
Classic signs of a worn out battery. Battery International has a great cross reference to find your battery: http://www.batteryinternational.com/ups-batteries.html
Oct 22, 2009 | Computers & Internet
Peavy viper 75 watt modulating amplifier stops getting power.
Your are on the right track. This fuse may look good but still be bad. once you in there all ways replace with new, it helps extend the life. 95% sure it s the fuse. If not it will need to go on the bench. Good luck DFD
Apr 11, 2009 | Peavey Music
Short Cicuit on my Buffalo external hard disk...Help!!!!!!!!!
First of all Hi!
This Fixya will help you solve this problem. First of all your hard drive should be still ok but you will require to open the hard drive enclosure and replace the power supply (due to the wrong voltage tapping). Please feel free to follow these fixya's not only to recover your photos but get back a working hard drive!
Solution 1: Check fuses
1. Disconnect faulty enclosure from any mains supply
2. If power supply is INTERNAL you will have to OPEN the enclosure but BEFORE you do that WITH THE hard drive UNPLUGGED TURN ON the power switch to discharge the hard drive's internal power supply
2. Open the enclosure and check for any fuses on the inside. There should be one located close to the power swtich from inside. Change it with one of a similar rating because most probably this is the culprit.
3. Try and power up the drive THIS TIME WITH the CORRECT voltage tapping
4. If the power supply is EXTERNAL you do not need to open the enclosure, just change the power supply with a similar one and you should be up and running again.
Solution 2: But the fuse is ok but there is bbq smell when i opened the enclosure!
1. Ok this means that you will need to get hold of the internal hard drive.
2. If you have another computer check if the hard drive is still ok! Here is how:
- Turn off the computer
- Open case , #
- Hook it up to the Internal IDE cable and the internal power connector
- Turn on the computer.
- You should have this detected in my computer as a new hard drive and you
should be able to see all the data in it
2. But probably you still want this as external dont you? Ok buy another enclosure from a computer shop (this time you will just need an empty one)
3. Plug the hard drive in new enclosure. If you're not experienced enough just give it to them to hoook it up for you and FINALLY you should have the reincarnated buffalo hard drive functional again.
Hope this fixya was of help :)
Best Regards
ALx
- Please take some time to rate this solution, really appreiciated thanks :) -
Jan 07, 2009 | Computers & Internet
Power
Check the internal fuse.
Oct 21, 2007 | Aiwa XC-RW700 2-Disc CD Recorder
Philips CDR770 CD Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
