Question about Music
I have a electro harmonix freedom amp that is crackling,distorted, and playing at very low volume. I tested speaker, it"s fine and battery is fairly new. Any idea whats wrong?
  • pat love Jan 18, 2013
    thanks for the info, i'm not a tec guy so i took it to someone who is, no prognosis yet.
mighty thor
  • 51 Answers
SOURCE: Fender passport model # 250 Used Only Twice!
go back in and find where the electrolitic capacitors connect to the board. They look kind of like a battery. One or both of them have broken loose from the main board, preventing any significant current from going to the output transformer, and causing overload. This is a common problem, and it does not take much rough handling to cause it.
where the break is is at the solder connection. Under a magnifying glass, the break will look like a little circle. Float fresh solder on that or any other large solder joints which may be cracked or broken.
Use standard precautions when working around high voltage.
Posted on Dec 02, 2008
SOURCE: The Distortion Pedal has no effect on the sound.
i got d same problm. i fixed it myself.. check all the op amp ic's if they're all gud. if youre not sure, replace all 4 rc4558 ic's. in my case, i still felt a very small output signal from my pedal (equalizers, vol n gain ctrls r gud since they vary when i change the setting) so i suspected that one or 2 of my ic's were damaged. i only replace d last two op amps which my signal passes thru. i also had this problm with my marshall drive master. same diagnosis and solution. check your schematics
Posted on Feb 13, 2009
  • 29 Answers
SOURCE: Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Posted on Nov 09, 2009
  • 5 Answers
SOURCE: Marshall DSL 401 runs fine for about 10 minutes
if this a tube amp then your tubes might be going bad. but if it is a solid state amp then im not to sure whats going on.
Posted on Apr 16, 2010
  • 73 Answers
SOURCE: I have a buzzing noise coming from my Marshall AVT100
okay so buzzing noise. i have seen this once before. the extension cord feeding a power strip with two amps plugged in and powered on off of a low amp electrical outlet with fluorescent lights overhead.......try running only one power unit off of the electrical outlet you are using, just one straight into the wall with the lights out. if you still hear it i wonder if the output transformer is starting to go south. if you listen close sometimes you can hear the buzz of a transformer powered on, example: you can hear the buzz of a power transformer on a power pole in peak hours. tubes usually make hisssing, crackling type noises. next would be to tap on the tubes while in play with an orange stick or pencil eraser to listen for microphics or the tapping itself thru the speakers. if you hear with out a doubt change them.
Posted on May 07, 2010
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Distorted speaker sound - only 18 months old not played at volume - is it likely to be the speaker or electronic ? Is this a common fault - will it happen again making this amp unreliable ? Not as...
this is a electronic problem. there must be a capacitor/s in the output section that's swollen and will keep giving the same problem unless its replaced.
G.
May 29, 2011 | Marshall Amplification Marshall AS100D 2x8...
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
Wires to main speaker are, Yellow & Blue witch one is the positive ?. Also I am getting distortion from the clean channel even at low volume, the speaker is Peavey 1230 model 8 ohms.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Feb 21, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a buzzing noise coming from my Marshall AVT100. It is present on all the channels. Is it likely to be caused by the valve? The valve inside is made by Electro Harmonix and it was made in Russia....
Apr 05, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
104 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
