I have a pink bleed on my Samsung plasma tv
Pink comes through on white background
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
Posted on Jun 19, 2008
  • 55 Answers
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Posted on May 09, 2009
  • 17 Answers
SOURCE: pink instead of bright white areas on my tv
I have the same problem.
But I heard they said to replace one of the boards but which one?
Posted on Jun 26, 2009
  • 304 Answers
SOURCE: Top half of my screen goes white and pink
First try using Component cables instead of the HDMI cables and see if that fixes the problem. If it does then you have a bad HDMI cable. If it does not then you might have a bad Y-Main bd or X-Main bd or a Main bd. It can also be bad buffer bds. Have a trained Samsung tech look into the problem.
Posted on Jul 16, 2009
  • 10 Answers
SOURCE: white has turned pinkish
sounds like the linear adjustment is out of whack.....most projection type tvs, projection, lcd, plasma, have to be correctly aligned so that the color grids overlap each other to properly display the correct hue being created. you'd need the service code to re-adjust it, or have it serviced. also possible that one of the color grids is bad, but if you have all three (red,blue,green) colors showing on the entire screen area i would doubt it
Posted on Aug 10, 2009
Magental background on all prints looking like a pink papr instead of white
That sounds like a white balance issue to me. Do you use manual white balance setting or auto white balance?
Nov 05, 2013 | Konica Minolta Bizhub C550
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
DVD picture is pink
check that all leads are pushed in
Nov 29, 2009 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Pink instead of bright white areas on my tv
Jun 26, 2009 | Zenith P50W26 50 in. Plasma Television
Pink pixils on light background
When this happens the voltages on some of the circuit boards can be adjusted to claer up this problem. THIS IS NOT some thing a person should do them self, the voltages are dangerous and critical to the operation of the set. "This should only be done by a trained service technician."
May 24, 2009 | Philips 50PFP5332D 50 in. Plasma...
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Pink picture with no green
take the color to b/w and retune
Apr 23, 2009 | Samsung PN42A450 Plasma TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
