Question about Sharp AR-M237 Copier
Lost key operator code for Sharp Copier AR-M207.
I purchased a Sharp Copier AR-M207 with all the manuals but the seller did not know the key operator code. I tried the default code without success. Does anyone know how to over ride or reset this number without the code?
  • dave664 Feb 06, 2009
    MickspaceNET,
    Your solution worked perfectly! The key operator code that was programmed in the machine was a sequence of numbers I never would have figured out. I am a small business and this saved me a lot of money. Thank you very much.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
  • philcool Mar 19, 2012
    Very good worl. I found my codes too. Now, how I clear total count of all in my AR-M206 for resetting to zero.
    New Friend:
I have a problem about Sharp copier AR M207 its calling warring (call for service 4H-00 can you help me please?
Posted on Dec 19, 2012
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I need a printer software to enable me print with my window 7 software
To help you install printer software for Sharp AR-M207, please find the link given below and find the topic mentioned as 'Software' and select Windows xp:
http://www.sharp-cee.com/cps/rde/xchg/scee/hs.xsl/-/html/product_details.htm?product=ARM207
GuruAid.com
Mar 31, 2016 | Sharp Used AR-M207 Copier Printer Scanner
I need a software that can enable me print from my 26 bit computer and my copier AR-M207 PHOTOCOPIER
You can download a printer driver from here.
http://www.sharp-world.com/support/download.html
Microsoft is ending support for Windows XP so I would suggest updating your operating softwaere.
Mar 09, 2016 | Sharp Used AR-M207 Copier Printer Scanner
HOW TO RESET SHARP COPIER AR-M350N AFTER FUSER WAS CHANGED. CODE H3-00 STILL APPEARS.
must enter into simulation mode. press"P""*"Clear""*" then press"14 " then press "start" then press"0" then "start" again. if 14 doesn't work substitute 15,16 or 17.
Nov 04, 2009 | Sharp AR-5320 Black and White Copier
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
Mar 25, 2009 | Sharp AL-1641CS Laser Digital Copier
I have a Sharp AR-M207 Copier , it has H2-00 on the display , how do I fix this .
"#" key “*“ key "C" key “*“ key then enter 14 press start machine will switch off then on
Feb 02, 2009 | Sharp AR-207 Copier
Sharp AR-M237 Copier Logo
4,489 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
