Question about Craftsman 680915001 Edge Guide
Attach edge guide onto skill jigsaw - Craftsman 680915001 Edge Guide
  • 843 Answers
I don't know why they even provide edge guides with jig saws, they don't work worth a flip. The problem is that, unlike a circular saw, the direction of cut is unlikely to be 90 degrees from the direction of the mounted edge guide. The blade mounting is not made to ensure that the blade is held exactly straight. When you follow a straight line with your cut you will see that the body of the saw will probably crab a bit sideways like a car that badly needs a wheel alignment. I suppose the edge guide can work on 1/4 inch plywood with an aggressive blade, but that will give you a very rough cut. Much better to draw the line and just follow it visually. If you need to do a lot of this, and you want a nice straight line, use a circular saw. Good luck.
Posted on Jan 16, 2013
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
How to lock the jigsaw blade to make straight cuts on my Boschest 1587svs?
Use a straight edge guide. Clamp it on the work so the jigsaw can run against it. Be patient and go very slowly.
Mar 04, 2017 | Blade Saws
How to remove blade wont budge with allen key
Hallo Ingrid
Pl send a picture Of allen bolt , if possible make a flate cut with hacksaw and open with screw driver.
Jayesh Desai
Jul 16, 2014 | Makita Jigsaw Blade
Setting up a jig saw to cut a straight 1/4 inch
You will need two C clamps and a straight edge,I use a metal yard stick.Whatever you use look down the edge a make sure it's true.
Set up on the line and make sure the blade is going to cut on the waste side of the line.Measure the distance from the edge of the wood to the other side of the jigsaw glide plate and make a mark.Transfer the measurement to the other end.I move the blade up just above the surface so I can set the jig saw on the wood while I get the measurements.The last step is to clamp the straight edge down.Make sure to have the clamps with the handles down.Check under to make sure you won't run into any thing and do a dry run to check for cord hang ups.This is the best way as long as you keep the edge of the bottom jig saw plate against the straight edge.^^^^ Well that's how I do it. good luck
You can all so use the T bar attachment that slides through the bottom plate and clamps down with thumb screws.Personally I like the straight edge.
May 10, 2011 | Skil 94500 Jig Saw Rip Fence
How do you put a new blade into a Black & Decker JS4000 Type 1 jigsaw
There is a black plastic switch where the blade is slid into the jigsaw. The black plastic switch can be seen and accessed from the front of the jigsaw through the clear plastic sight guide...You pull the black switch toward the bottom of the jigsaw and it opens the space for the blade to slide into, when you release the switch it will close the space and lock the blade into place.
Hope this helps.
Mar 06, 2011 | Garden
This jigsaw seems to suffer from the same problem as its predecessor. Whenever i use it to cut through a kitchen worktop or any material it never gives a straight vertical cut through the material but...
I can't speak to the diffuculty you're having with that particular model, as I haven't used it. But in general, the stability of the cut depends upon the guide mechanism of the saw, and a three point guide is better than two point or single point. A three point guide assemble will hold the blade firmly locked when inserted into the column, will have a roller bearing that supports the center of the blade path, and will also have a finger pinching mechanism at the base near the material, so the blade can't waffle in the cut. Aside from changing saws, all I can recommend is that you make sure the base is correctly locked in place at an angle square to the blade, when fully extended. Check this with a small trysquare against the base, and look from both sides of the blade. Some folks will even attach an auxiliary base to stiffen theirs up, though this shouldn't be necessary. Then make sure you're using a sharp blade with the correct tooth count for the material you're cutting, and don't force the cut. Let the saw do the work, and make sure you hold the base firmly against the worktop as you cut. If you force a cut with the orbital action on full, you'll get more deflection.
Other than that, all I can say is that I've had good luck with the newer Bosch jigsaws, and the best cut I know of comes from the Festo, but we're talking serious dollars there.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 19, 2010 | Hitachi CJ110MV D Handle Jigsaw
Blade wonders on straight cut
When doing any straight cut use a straight edged piece of something to run the jig saw along, using as a guide, this will usually keep it all straight, sometimes it can be a loose blade, or a bent shaft?
Mar 08, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
How to attach Singer Free Motion/Darning Foot to Singer 7442 machine?
To learn the skills to repair sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Oct 15, 2008 | Singer 7442 Mechanical Sewing Machine
How to use clipper attachments...
Used against the scalp, around the ear, on the left and right side... working against the growth direction from behind the ear to the front of the ear.... The angle of the back of the taper guide comb makes it easy to create a smooth, progressive, natural taper along the edge of a men's clipper cut. Do this after you have used a regular guide comb to take down the general perimeter length and you will have a nice tapered edge to the clipper cut around the ears.
May 28, 2008 | Health & Beauty
Craftsman 680915001 Edge Guide Logo
67 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
