Question about Gateway GT5622 PC Desktop
GT5622 fix internet card
I keep loosing the internet connection, the provider "CenturyLink" has sent me 2 new modems, and 2 new cable cable connectors (yellow wire) from the modem to the harddrive. I have to either "restart or reboot the computer to connect, then it will last for 5-15 minutes.
  • Gateway Master
  • 27,725 Answers
Either drivers are unstable or loose connections faulty or crimpted ethernet lead
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Posted on Jan 16, 2013
russolini
  • 47 Answers
SOURCE: network adapter not showing up in device manager
The tech was incorrect - your network adapter is just not recognized by the system. If you install the correct drivers for your particular network adapter it should be recognized, which should then solve your problem. Search the Gateway website for network drivers for your particular desktop, and if the network adapter was added (not built into the computer) then determine the manufacturer and model of your network adapter, then search the manufacturer's website for the correct drivers.
Even easier, if you still have the original disks that came with your computer and/or network adapter, they should include the correct drivers.
Hope this helps!
Posted on Jun 10, 2008
Blu3Demon
  • 76 Answers
SOURCE: says modem is being blocked
Right click on my computer go to properties and click hardware from there click device manager find it in the listing find the modem and check its properties to see if it was disabled if that doesn't help follow the steps again and delete it and reboot
Posted on Mar 12, 2009
ajitvd
  • 89 Answers
SOURCE: Problem with sound card, modem & broadband connections after storm
storm doesn't cause any problem to software may be you have replace your hardware it mite have problem in some ICs...
Posted on Jul 17, 2009
Moe2010
  • 62 Answers
SOURCE: My computer is having connectivity issues. At
Check your firewall settings. They may be blocking access.
Posted on Jul 17, 2010
gotgeek2
  • 565 Answers
SOURCE: I have a Gateway 310-S
If indeed you have the Gateway 310-S 2900621 go here:
http://support.gateway.com/s/PC/310_Series/2900621/2900621nv.shtml
If you don't have the 2900621, then go here and select your model:
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=310series.html
Posted on Nov 08, 2010
Will motorola Sb6140 work with century link internet
centurylink looks like its dsl (which uses a home phone) ppoe
comcast uses cable connection (like cable tv) don't think their compatible
call centurylink to be sure
Feb 22, 2016 | Arris Surfboard Extreme Sb-6121 Docsis 3.0...
Tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 | Computers & Internet
Powerline adapter wont work with directv dvr
Different modems have different configurations - your new provider should be able to assist you in getting connected.
Sep 14, 2017 | Powerline Ethernet Network Adapter
Wireless connection issue w/ ZyXEL PK5001Z DSL Modem/Router
Try switching your WiFi Channel to 11. In your web browser (while attached to the internet through the ethernet cable), type in 192.168.0.1, log in using info on back of modem, or use your custom admin password if you changed it. Select Wireless Setup. On the left hand column select Radio Setup. In the drop-down menu, select channel 11 instead of auto detect. Apply changes to save the setting. Hope this helps.
Aug 18, 2012 | Apple Computers & Internet
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this "laptop" to enable getting wireless connection of internet?
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Jul 29, 2011 | Dell Inspiron 5100 Laptop
Where i can connect internet line?
To connect to the Internet you need a few extra things aswell as a network card.
Mar 08, 2011 | Compaq Armada 4220T Notebook
Modem keeps loosing connectivity. I have to turn off the modem and restart it to access the internet. Running 2Wire Gateway.
call your internet service provider and report first this incident. in most cases its with the service provider that has problem causing disconnection in your internet.
Take a look also with your modem device, observe when you got disconnected does led indication lamp turn off or your modem restarted itself. that could also be a problem with the power supply of your modem. better check with multitester if output voltage from power supply is dropping.
go check also the ethernet cable if this is not loose, fix it properly, you should hear a snapping sound means it is lock properly.
Feb 09, 2011 | AT&T High Speed DSL Modem
I have a Belkin N wireless router, model F5D8236-4 v1. I am unable to connect to the internet using the router and I've even tried resetting the router with no luck. The "modem" light on the...
i have a belkin N wireless router model:F5D8236-4 v1 i have had it installed on my computer but it has since been wiped so there is no trace of me having it installed, since this i have moved home and ost the disk that came with it but i need to put the router back on due to my daughter having a laptop, how would i get the software for it if i have no disk?? please help!!!!!!!!!!!
Jan 07, 2011 | Belkin (F5D7231-4) Wireless Router
I have a Motorola SURFbiard SB5100, and as far as I know, everything is properly plugged in. The "POWER," "RECEIVE" and "PC/ACTIVITY" lights are all on, but it won't make it...
First,check all your connections,especially the cable wire,make sure they are all secure.
Reset your modem by unplugging the power for 30 seconds to 1 minute and plugging the power back in.
This will reset the modem,if you have a router inline with the modem rest that also.
Plug in the modem first ten the router,wait 1-2 minutes and try to get online.
If this still doesn't work, call your internet provider,it could be a problem with them or a problem with your cable.
Dec 24, 2010 | Arris SURFboard SB5101 Cable Modem
I have DSL/verizon,modem 6100F i keep loosing my internet connection
Your problem definitely sounds like an intermittent connection problem. It can either be one of two things. #1. You have a defective modem, or #2 It's a network problem. I will definitely go with #2. Here's the thing. The problem you have is very very very common not only to Verizon DSL customers, but also to other Internet Service Providers as well. The best way to fix the problem is to understand what's causing the problem. There are two types of intermittent connection problems. The first is Intermittent Sync. You'll know if you have this problem because the DSL light will be blinking everytime you get kicked out. That means there's no internet connection, The modem cannot detect and establish a connection with the Central Office. The second is Intermittent route (which I know is you're problem), The DSL light is steady, but the Internet light almost always turns OFF or turns RED. The only way to fix this problem is to coordinate with Verizon. The reason is because the problem is outside your house. The long cable lines, the drop wire, the cables that passes through from the Central Office to your House can all be damaged, If that's the case, then a technician is required to go out and fix the problem. Don't worry about calling Verizon, this is a network problem and you won't be charge for anything. I know losing internet connection is very frustrating. Give your ISP a chance, they will definitely fix the problem if you give them the opportunity to do so.
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Gateway GT5622 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
