HOW CAN I FIX ERROR CODE F202 ON SHARP AR-455MT?
TONER IS NOT INSTALLED CORRECTLY
sir fixalot
  • 146 Answers
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Posted on Jan 06, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 126 Answers
SOURCE: sharp ar 250 copier error code CH
CH - open cover in the paper feed area
CH blinking - Dev unit is not properly installed
For the 'CH' check the covers and make sure all covers are closed properly.
For the 'Blinking CH' take the dev. Unit open and the reinstall unit properly.
Pls rate – thank you
Posted on Mar 03, 2009
I just finish refilling toner on my AR-5127 Sharp photocopier and this error code H2-00 appeared what most i do to correct this code
I would check the fusing unit section, the heater lamp, thermostat and the thermistor continuity. Fix it first then clear the error code afterwards.
Jan 10, 2018 | Sharp Office Equipment & Supplies
Error codes f2 sharp ar
Identification error
Model error
Type error
Destination error
Data abnormality
Misc error
It is always recommended to use OEM toner. The toner you need if AR-310NT
Brother Printer Support
Jan 20, 2014 | Sharp AR-310NT Toner
I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
May 08, 2009 | Sharp AR-507 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Error code Sharp AR-M 257
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ARM-455 F202 error code and says check toner cart.
There is any solution for error F2-02 without changing any Toner Cartridge
Jun 05, 2008 | Sharp Office Equipment & Supplies
May 23, 2008 | Sharp AR-M237 Copier
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
24 people viewed this question
k24674
jasbo
jasbo
