Question about GE Refrigerators
Veg drawer in lower part of frig frezzes the veg. setting on ref is 4
All other parts of ref seem to be fine.
    Problem Solver:
  • 15 Answers
NEED TO CHANGE TEMPERTURE CONTROL IN UNIT. NOT CUTTING OFF SOON ENOUGH AND COLD AIR SINKS. ONLY A MATTER OF TIME AND OTHER THINGS WILL START FREEZING
Posted on Jan 18, 2013
aborcass
  • 2651 Answers
SOURCE: Need Help - Galazy Refrig. 18 cu ft
you can pop that model number in at their site sears.com.(look for parts section on there homepage. you see complete exploded views of your refrig pick out what you need rightt here
Posted on Mar 22, 2008
flashjlg
  • 5 Answers
SOURCE: too cold in frig
Check for a faulty thermostat it is responsable of shutting down the compressor when it reaches your desire temp.
Posted on Mar 06, 2009
  • 125 Answers
SOURCE: in the frezzer ice is forming under the floor and
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Posted on May 05, 2009
  • 2418 Answers
SOURCE: We have our Sub Zero model 650 frig set to 35
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Posted on Jun 29, 2009
  • 1218 Answers
SOURCE: Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Posted on Dec 15, 2009
Having problems with defrost, water in veg. bins
Sounds like a blocked drain and a thermostat faulty or faulty sensor.Sensor will have to be replaced and drain unblocked.
Aug 19, 2015 | Refrigerators
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
Veg./ meat drawer items are freezing? Thermostat are set at factory suggested settings. What can we do to solve the problem?
factory suggested setting are just that "suggested" turn your thermostat down to a lower number, turn it down just one notch and see if tht solves the problem, if stuff still freezes, turn it down (lower number) more.
Mar 19, 2011 | Refrigerators
WATER DISPENSER HAS STOPPED WORKING, HAD BEEN WORKING FINE THEN JUST STOPPED. WASNT SURE IF FILTER JUST NEEDED TO BE REPLACED OR IF MAYBE THE WATER LINE WAS CLOGGED. THE ICE MAKER IS WORKING FINE,
check your water tank in ref. it is behind veg. drawers.. if water tank is full. might check water soldnoid in b back of ref. there should be two one for ice maker and one for water..ok
Feb 13, 2011 | GE GSH25JFR Side by Side Refrigerator
Water does not come out of door. I can hear the click and the ice is working on the other side so it is getting water.
check your water tank in the ref. looking under the veg. drawers. there it should be on the back of ref. if no water than your solenoird in back of ref. might be bad. there is two one for ice maker one for water.. ok
Feb 11, 2011 | Whirlpool Refrigerators
Water collecting in veg drawer and on shelves also freezing items in frig
Check the defrost drain in the back of th freezer. It may be clogged.
Sep 18, 2009 | Whirlpool Refrigerators
Mar 22, 2008 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
