Question about Emerson 1F89-0211 Blue 2" Thermostat, Heat Pump, Non-Programmable
The schematics to my Emerson Thermostat 1F89-0211. Thank you!
The wiring is incomplete and I do not have any paperwork so that I can turn my heater on.
How to install Emerson non digital thermostat
turn power off, take pic of wires, wire new one the same way, turn power on
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 06, 2018 | Emerson Heating & Cooling
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Oct 15, 2012 | Heating & Cooling
I have a goodman furnance there is a loose green wire coming from the motor where does it go? Please help me.
Hi, W/D here.
A short green wire usually indicates a ground wire, and can sometimes have a terminal attached to the end of it. This wire would go to the frame of the furnace, as a ground wire for the motor, bonding the motor to the frame electrically. Usually, it is attached to the frame at the nearest point of contact, which usually is a motor attachment screw, or a green colored screw in the panel near the motor, and will sometimes have the grounding symbol near it. Before making any connections, check your wiring diagram first. It will be either in your paperwork with the furnace or attached to one of the panels near the motor. It can also be located inside the furnace electrical panel on the furnace, so make sure that the power is turned OFF (trip the breaker, and test it) before opening the electrical connection panel. Once you locate the schematic with the motor on it, find the green coded wire on the schematic and see where it goes. My experience has been that it will be a ground wire, but you have to check.
Best regards, --W/D--
Oct 20, 2011 | Goodman GMS90703BXA Heater
Code c776 on a rheem tankless hot water heater. How do I disconect the remote and let water heaterdefault to 120 degrees??? I have the UMC-117 remote. Also any way to put a thermostat on this thing to...
The remote is hardwired to the tankless unit.
Turn power off. Open front cover, and locate wire connections and disconnect. Turn power back on. Open hot tap and see if unit works at 120 degrees F default temperature. If not, then problem can be PC board.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Typical schematic showing remote controller connection:
http://waterheatertimer.org/images/Tankless-wiring-1200.jpg
Some tankless units have built-in freeze protection.
I live in Texas and did following to protect my outdoor water heater: Thermostat controlled heat tape around pipes, and build a box around water heater out of styrafoam, and then put light bulb inside styrafoam box. I hooked up 120Volt mechanical thermostat to light bulb circuit.
Open following links for error codes, typical manuals, Rheem contact phone and chat, plus regular maintenance manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Home
When i plug in the insink erator and turn it on it blows the breaker is it the heating element or the switch or the thermostat
The first thing I would check would be the switch. then the thermostat then the element.I would also check for any burnt insulation which could allow a short to ground.
My gut feeling would be the element but I like to eliminate the less expensive items first. Hope this helps. Thank you and have a good holidays.
Dec 22, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
I have a black wire, a white wire, and a ground for supply. I have one red wire and one black wire on thermostat. I have two black wires on the heater that are wire-nutted together. How do I connect...
If this heater is 220 volt and the stat is 120 volt. Here you go. One black wire from the heater should go to the black wire on the thermostat. The red wire from the stat to your black wire in the electric rough in box. The other black wire on the heater will go to the white wire in electric rough in box. The ground to the appropriate ground screw on the heater and the stat. If you are not a licensed electrician in your state, you should hire one especially if you do not understand electric characteristics and the way energy moves or if you can not read electrical schematics. You can get seriously injured or killed wiring up electrical devices. Do not wire this heater up if your not sure of voltages, phase, and amperages.
Nov 19, 2010 | Fahrenheat Built-In Baseboard Thermostat...
Need to know how to wire a thermostate to a hanging emerson heate
If this is an electric heater without a relay, you'll need a high voltage (electric heater) thermostat.
Is this a new installation? Give me some more info and we can get this job done...
Charlie
Aug 21, 2009 | Heating & Cooling
Emerson 1F89-0211 Blue 2" Thermostat, Heat Pump, Non-Programmable Logo
22 people viewed this question
Top Emerson Heating & Cooling Experts
Tim Whalen
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
