Question about HP Compaq Presario 1700T Notebook
Compaq Presario A900 Wireless Wont Turn On
I can't seem to turn on my wireless device, the switch is turned to the correct position however the light will not change from Amber to Blue. I? have attempted to manually turn on via the support pages however this is not working. The option to Manually set up a wireless connection has also disapeared. please help
  • 4 Answers
-- do you have the wireless connection ikon in network connections, -- if yes try to find the wireless networks in range by right clicking on the ikon and than get connected. check if that works.
Posted on Jan 24, 2009
Compaq presario a900
A common issue is a damaged motherboard GPU. Rework is probably required with a specialist service.
Aug 22, 2013 | Compaq Presario A900 Laptop Universal AC...
My compaq presario cq60 wont turn on
Does the laptop boot? Sound? Do you see a "ghost Image" in the monitor in a bright light? If so, Could be backlighting, Inverter, on/off switch that shuts the monitor on/off when you open and close the lid. Can you boot to safe mode with networking? If so, Open the Device Manager, Uninstall the Graphics Adapter, reboot, the software will apply a generic driver, If the Graphics adapter has not failed completely.
Jan 24, 2013 | Compaq Presario CQ60-220US PC Laptop
My Compaq Presario M2000 wifi light is "On", but
While logged into the router, Turn on "broadcast ssid" or tell your computer exactly what the SSID is. One form of security is to set the router not to tell other computers in wifi range what the ssid is.
Nov 08, 2011 | Compaq Presario M2000 Notebook
Hi, my wire less internet was working and now i cant get it to work. on the icon on the bottom of the screen when you click on wifi it has a red cross on it.it says something about the setting is turned...
It sounds like your WiFi switch was somehow shut off.
hpweb_1-2_minus.gif Wireless device is turned off or disabled The power to the wireless network and Bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02448899.jpg and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02448900.jpg will display.
  3. Or you can try pressing the Fn and the F2 keys at the same time to enable your wireless adapter.
  4. Here is a link for your product support page at Hp.com : http://h10025.www1.hp.com/ewfrf /wc/searchResults?tmp_product=Compaq+Presario+V6000T+CTO+Notebook+PC&product=3177516&tmp_qt=turn+on+wireless+switch&lc=en&dlc=en&cc=us
Apr 21, 2011 | HP Compaq Presario V6000T Notebook
My wireless wont turn on or connect every other computer in ofice connects
There should be a key at the top with a blue symbol that looks like a vertical line with an upside down triangle on top. Hold the Fn (function) key and hit this other symbol. This should turn your wireless adapter on.
Mar 02, 2011 | HP Compaq Presario V6133CL Notebook
I have a compaq presario v5000 but the wireless switch cannot be turn on
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Also
have you gone into your device manager and seen if the wireless network device is turned on/enabled?
Nov 15, 2010 | Compaq Armada M700 Notebook
Cant get the wireless to turn on
There is a switch in the front of the laptpo. You need to switch it on. The light orange indicates its off and blue light means the wireless is on.
Also go to device manager and under network adaptor make sure the wirless adaptor is installed
Jul 02, 2009 | Compaq Presario M2000 Notebook
Wireless Switch
From your description I agree, its probably a damaged switch. I never recommend anyone taking apart a laptop unless they are a mechanical whiz, have experience with laptop disassembly or can afford to break it beyond using. As far as turning the built-in wireless card on without the switch there might be a way. I don?t have a Compaq laptop to experiment with, however, my Dell Latitude BIOS settings has a setting to automatically turn on the wireless card at boot-up. Perhaps yours does too, during your laptops initial boot process get into your BIOS setup menu (press F2 or if that doesn?t work F10 keys). Look for an option relating to your built-in devices or wireless device. My Dell setting is fairly ovious: "Turn on wireless device". If you find a simliar option turn it on, reboot and look for the wireless adaptor. Another option may be to buy an inexpensive UPS wireless adaptor. You can pick them up on Ebay for around $30, not as spiffy as the built-in but probably a lot cheaper than paying a repair shop to fix a three year old laptop. Good luck.
Dec 02, 2006 | Compaq Presario 2100T Notebook
Computers & Internet Logo
2,682 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
