Question about Ovens
I have a whirlpool double oven model akz161/03/ix. My power triped and the cooker fuse on the fuse board was triped. When i reset everything my oven was showing 'stop' on the display. I reset
4 Suggested Answers
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
  • 19396 Answers
SOURCE: I have a Whirpool AKZ451/IX/01
There had been a short.I think the only replaceable fuse is the one built in with the power cord. This kind of oven usually do not have replaceable fuse in control board.
If the range top ignitor is not working, check the power cord first. If it is fused replace the fuse. If that does not help the power cord should be tested to check if it is broken. Test is done using a multimeter to make sure that the power cord circuit is not open or shorted..
The point where the short usually occurs when you replace the element is the fan wiring. Check fan wiring harness and the fan motor itself. If the appliance is tripping the circuit breaker the oven can be tested for few seconds with fan not connected. If it does not trip, then the fan is shorting.
If oven is tripping check also element's wiring.
If the oven is working (turning on) but there is no heath read temperature probe impedance, double check elements and wiring. The problem can be the temperature sensor located inside the cavity.
Posted on Aug 23, 2011
  • 39 Answers
SOURCE: Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Posted on Sep 05, 2012
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Nov 30, 2016 | Whirlpool Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
Aug 06, 2014 | Whirlpool Ovens
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Hi can you please tell me where i can obtain a user manual for a whirlpool electric cooker akz446/IX
whilpool has a very good sight , and you can download for FREE the manual you n
Jul 27, 2011 | Whirlpool Ovens
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Hi--my whirlpool double oven,model gbd277pds10 all of a sudden has a blank panel ,nothing works ,when you touch a command it just beeps, can anyone help me, please..
Getting beeps when you push the keypad buttons means that power is getting to the control board. First, try shutting off the breaker to power down the oven for a few minutes, then turn back on. This will force a system reset, hopefully the oven will recover.
If not, you probably have a problem in the control board. If this is the case we may be able to save you some money if you can get the board pulled. We repair oven controllers at
Sep 10, 2009 | Whirlpool GBD307PDS Electric Double Oven
No diplay or oven light
control board is bad, contact sears to ix
Jun 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Oven Shutdown Fuse
you need a new fuse it is not resetable should use renches but be carful if not comfortable call service
Apr 19, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
142 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
