Question about Brother HL 5040 Laser Printer
My Brother 5040 laser printer is printing a bit faint in parts of the page. I have cleaned the rollers, shaken the toner cartridge and replaced the drum unit. The quality is better, but I am still missing areas. The toner unit has still got toner, but it may have been a bit damp due to where it was stored. I have tried to increase the darkness settings and tried the grey tick box in the advanced settings. Nothing else seems to help. Just ordered a new cartridge of toner, and it should be here in a few days but was this the original problem? Any advice would help
    Champion:
  • 320 Answers
Number one are you using brother oem drum and toner? generic toner will give you all kinds of problems,.. if the the paper is damp or has moisture in it it will give you weird printing , ghosting parts missing etc. good luck brother sr tech
Posted on Jan 24, 2009
For the brother mfc 7820N the toner life end pops up and i have tried the *00 to reset and it doesnt work. What do I do?
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Feb 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Get more ink from 8480 toner cartridge
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge alsoreplaces worn parts as well as refilling with toner powder.
Jan 22, 2012 | Brother MFC-8480DN All-In-One Laser...
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
My Dell 1700n Drum and Toner Cartridge were both replaced when the drum replace light blinked and the print was getting lighter. Despite resetting the Drum counter the printer still only prints faintly...
Have you checked the fuser?
A laser printer fuser assembly is the heating roller unit that melts and fuses the toner onto the paper. The fuser assembly is made up of a heating roller and a pressure roller.
The heating roller applies the heat to the toner on the printed page and the pressure roller presses and fuses the toner into the printed page. If it's bad and not heating properly, the print will be faint, which is what you describe. You may be able to remove and clean the fuser, but if the printer gets lots of use, it may just be worn out.
See this link for an idea of what it looks like and a price.
http://www.fastprinters.com/ProductDetails.asp?product_id=DELL-H4919
I do not work or represent this company, so shop around.
Mar 22, 2010 | Dell 1700n Laser Printer
Laser printer horizontal streaks go away after a few pages
The operating principles behind laser printers are fairly simple. In fact, Brother machines more closely resemble large copiers than conventional laser printers, this is why they are so reliable.
There are a couple of things to look at:
On the drum unit: is the imaging drum worn or scratched? When did you last clean the corona wire?
If the drum is scratched or otherwise with defect it should be replaced. If the corona wire is dirty it can fail to properly charge the drum and lead to print defects.
On the toner cartridge: Does the toner roller have any noticeable lines or banding in the toner?
Behind the toner roller is a "Doctor Blade" that ensures an even and consistent coating of toner. If there are lines in it they can produce print defects as well. Lines would be likely caused by toner accumulation on that blade. If there are lines, are you are careful, you may be able to clean the blade by gently and slowly scrubbing the non adhesive end of a post-it note between the toner roller and the doctor blade where the lines are.
Jan 15, 2010 | Brother HL-2070N Laser Printer
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Vertical Stripes on printed Page, Shaken Toner, Relatively new Belt (Green thing), cleaned the fuzer wire, cleaned the cleaner roller, has oil.
Depending on the type and model of your printer this could be several things mostly related to the cartridge or drum if you have a separate toner/drum system.. Since you have stated you have shaken the toner, I am assuming you have a laser printer. New belt, has me confused. Green thing leads me to think you are talking about the drum. If so, did you purchase a new toner cartridge or new drum cartridge?
Several components inside the toner or drum cartridge will cause vertical streaks. It depends on where these streaks are occurring and how wide the streaks are. We call these repetitive defects and they can be measured to determine which part is at fault.
Also, if this is a multi-unit machine (print/copy/fax/scan) Check the platen glass or ADf feed unit for white out. That has been a major culprit of vertical streaks on the page.
More specifics about the model of machine and cartridges being used would be helpful in trying to solve this problem for you.
Nov 14, 2008 | Brother Office Equipment & Supplies
Brother Intellifax 2800 Faint Print
did you remember to remove the pull tab to allow the new toner to be utilized? it's either that or you just have a defective toner cartridge which if you replace will take care of the issue. If you have used canned air to blow out your machine it is possible that the toner dust has been blown into the laser housing and fogging up the mirrors that it uses but that's kinda a last resort check...
May 07, 2008 | Brother IntelliFAX 2800 Laser Fax
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Jun 18, 2007 | Tally T8006 Laser Printer
Brother HL 5040 Laser Printer Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
