Question about Pioneer CDJ-800 Turntable
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
I bought a pair of CDJ 800 mk2's from the US and i live in the UK, i blew both fuses stupidly plugging them in over here with only an adapter, ive replaced the fuses but am i going to be ok to run them on a standard step down converter or can this damage them? Is there any other way of using these american cdj's in the UK? Thankss
  • Pioneer Master
  • 5,259 Answers
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Posted on Jan 16, 2013
  • 1 more comment
  • James Jan 16, 2013
    Thankyou so much for the info, i guess im just going to test them on the converters and see if they run ok, very helpful solution thanks
  • richard vreede
    richard vreede Aug 16, 2014
    Use your head pls, didn't you really not knew the powerdifference?
  • richard vreede
    if you're lucky, which i think you ain't , it's a fuse, but i think your transformer is dead. And pioneer is annoying expensive when it comes to parts, my monitor abs front was more expensive then the whole unit:), amazing. Just scratch monitors, recapped with better stuf and removed the soft inside and but stiffer absorber stuf in it, which gives it a tighter bass, but those prices amazed me. That why i won't buy a thing from pioneer, even if the new turntable will be grate, which it ain't. But the mixer and given partquality are shamefully gr richard
djproaudio
  • 515 Answers
SOURCE: cdj 800 keeps skipping
Does it keep skipping, or does it keep looping? 2 very different things. If it's skipping, it will sound like it's scratched, and will only skip on some CDs, and not others - unless your tray is messed up.
- Davis
DJ Pro Audio
www.djproaudio.com
www.djprolab.com
www.1200s.com
Posted on Jul 26, 2008
SOURCE: CDJ 800 Has no power
this guy don't know what he is talking about,the cdj800 does have a fuse,if you open the unit up just make sure it's unpluged,if the fuse is blown replace it with one of the same rating,it's right next to the switch inside the unit,it's very easy to take apart just 5 screws,I have one that won't power on also but it's not the fuse,but yours could be,just check it out and don't be afraid just be careful when handling electronics so that you don't send static charges into the chips.
Posted on Feb 05, 2009
djproaudio
  • 515 Answers
SOURCE: CDJ 800 mk2. Will play audio cd fine but won't play mp3's
There is no easy fix for this. You will more than likely have to have the CD traverse assembly replaced - you could try a professional cleaning and alignment first - but ultimately, you will have to replace the cd assembly.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
djproaudio
  • 515 Answers
SOURCE: replacing cdj cue buttons
Not hard at all. Just have to open her up. I would suggest purchasing the service manual, which has instructions on doing this and useful for other repairs, as well as parts list, and parts diagrams.
Pioneer CDJ800MK2 Service Manual
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Posted on Apr 30, 2009
djproaudio
  • 515 Answers
SOURCE: Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Posted on Aug 30, 2009
Hello i need some help,i have pioneer 800 mk2 cdj i buy from usa but im live in london so difirent pawer supply here i bought the converter but try connect and its not showing nothing maybe the problem...
You can have a fuse problem only in you plug it diectly to 240V, the UK voltage. Check that the converter is a step down transformer, 240 to 110 volts. The system should work with 110Volts. If everything is ok, then you blew the system´s powersupply with the 240Volts. that is difficult to solve.
Dec 08, 2010 | Pioneer CDJ-800MK2 Turntable
Pioneer CDJ-800 Turntable Logo
165 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
