Question about NAD L40 CD Player
NAD L40 My tuner just stopped working on the unit.I have tried using my other receivers arial but still no luck.Upon opening the unit I discovered two blown fuses,I replaced both (with exact same) thinking the problem would be solved, but still no luck.The cd player is still playing fine. Anything else I can look at before sending in for repairs? Thanks Deon
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
1.due to some short circuit in your receiver circuit has made the fuses blown
2.Replacing the fuses alone does not get solve.
3. Check the reciever power circuit
4. check whether output is being short circuited
5.Contact service centre
Posted on Dec 22, 2007
SOURCE:
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
Who can repair my NAD T761 in the Newcastle upon Tyne area
Hello
Get into this link and find the authorised service center for Nad at your area.
www.yell.com/.../video+player+repairs-newcastle+u... - United Kingdom
Nov 20, 2011 | NAD T761 Receiver
My Sony cd player spins but won't play. Cleaned
Those CD cleaners rarely work. They are nothing but small brushes on a plastic CD. Unless the problem is loose dust, they won't work. Try carefully opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, post the model number and I'll provide the replacement optics part number and cost. Some units have replacement optics that cost less than $15. Dan
Jun 15, 2009 | NAD L40 CD Player
We have moved to new zealand will the NAD c422 work here?
You can usually get a power converter locally so you can use products from a different country. I have no idea what radio stations you can get....:)
Mar 21, 2009 | NAD C422 2 Channels Tuner
NAD 7140
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Nov 22, 2008 | NAD 712
NAD tuner
Depending on your audio power needs, any will work except receivers that already have integrated tuners.
Apr 21, 2008 | NAD C425 Am Tuner Tuner
Receiver (tuner) signal fade-out ---heat related
The main problem with the 7140 is that there are at least 3 versions that I am aware of. The varient is based upon the serial number. Can you post that here. I will look up the info for you. I have access to some NAD stuff. Post the part designations as well (Qxx) and I'll at least get you the exact part numbers etc.
Dan
Mar 23, 2008 | Audio Players & Recorders
High pitch sound even with speakers disconnected
1.the problem with your audio processing circuits and improper power filter
2. Check audio amplifier coupling capacitors
3. Rectifier capacitors
4. contact service centre
Oct 26, 2007 | NAD L40 CD Player
NAD 402 Tuner problem
It's sounds like a chip gave up the ghost. You may want to try
turning in on and off a few times to see if you can get the culprit
to function properly again. Electronics are strange creatures in that you can at times just shake them and they will begin to function properly again. A loose wire here or there, instead of any real problem.
However, if the problem's more serious, given the cost of servicing these products, you may be better off just going to Ebay and buying a used one.
I recently purchased a nice used NAD 402 with original box
for $58. Upon arrival I found that the backlight to the digital display was not functioning, however the display itself was, and the sound of the tuner is amazing. It is nearly the equal of many tuners which I have owned in the past at as much as 50 times the price.
Best of luck to you...
Sep 06, 2007 | NAD Audio Players & Recorders
NAD L40 CD Player Logo
364 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
cheekygr1n
Level 1 Expert
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
