Question about Texas Instruments TI-83 Plus Calculator
How do you calculate cos squared? - Texas Instruments TI-83 Plus Calculator
  • Anonymous Apr 23, 2009
(cos(x))^2
Posted on Feb 18, 2009
How do i graph a circle in parametric mode?
The simplest way is
X1=cos(T)
Y1=sin(T)
Set angle unit to radians,
Set the Zoom window to SQR (square), otherwise your circle will look like an ellipse.
Sep 04, 2014 | Casio FX9750GII Graphic Calculator
Cos theta 50
To calculate the Cosine of an angle, you first make sure that the angle unit on your calculator is set to the correct one (degree, or radian). After that it is all simple. Enter the angle value (50 degrees) then press the [COS] key. If you get an error then press the COS key followed by the angle value then press =.
Note if your calculator display Cos ( , with a left parenthesis, then you have to press COS first followed by the angle value and possibly the right parenthesis.
Note. The theta here is of no relevance.
May 27, 2013 | Casio FX350MS Scientific Calculator
How do I cos square something im not getting the correct answer doing this.
Take the cosine of the number (cos key), square the result (x2 key). Make sure the calculator is in DEG and not RAD mode. Most elementary trig is conducted in degrees, not radians.
Apr 25, 2011 | Texas Instruments TI-83 Plus Calculator
How do i convert the answer of cos(30) which comes out to 0.8660254038 to a fraction?
I am sorry, my friend, but you are asking the impossible. The reason is that the exact value of cos(30 deg) is equal to square root (3) /2 which cannot be fraction (the square root of 3 is an irrational number).
However, it may be possible for your calculator to give you a result with a radical (3)/ 2 but that is no fraction. (A fraction must have both numerator and denominator as integers).
To get a radical result set the IO mode to MathIO.
Press [SHIFT] [MODE] to open (SETUP) and select [1:MathIO]
Feb 18, 2011 | Casio fx-300ES Calculator
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
Find cos 32° 45'
Look at the column of keys under the ALPHA key. You have the integral, the square root, and then the key that has a degree sign, an apostrophe and a double closing quotation mark. That is the one you use to enter the angle in sexagesimal notation. To simplify my task I will symbolize the key with [DMS], degree, minute , second.
To calculate cos (32° 45')
you press
[COS] 32[DMS]45 [DMS] ) and press [=] The result si 0.841039013
Hope it helps.
Nov 08, 2009 | Casio FX-115ES Scientific Calculator
Cos+tan(sin)=sec
This is a trigonometry problem not a calculator's.
cos(x) +tan(x).sin(x) = ( cos(x) + (sin(x)/cos(x)).sin(x). After reduction to the same denominator (which is cos(x)) you obtain
{cos(x).cos(x) + sin(x).sin(x)} divided by cos(x).
The content of the bracket above is just 1.
Your fraction will have 1 as numerator and cos(x) as denomitor. That is exactly the definition of the secant function i.e. Function sec is the reciprocal (not the inverse) of the cos function, while the arccos is the inverse of cos.
A mild advice: Avoid writing function without specifying the argument (the variable on which a function acts).
Note:
Aug 14, 2009 | Casio FX-115ES Scientific Calculator
Cos^2
cos(number)^2
(or use the square button)
Feb 09, 2009 | Texas Instruments TI-83 Plus Calculator
Cosh Squared or Cubed
if you want to square sin(3), press:
sin
Sep 24, 2007 | Texas Instruments TI-89 Calculator
TI-89 Problems
There isn't anything "wrong" with it.
Go to mode, and set the results of your inquiries from Exact to approx.
If you put in cos(e^2), it will print out cos(e^2) because it's the most exact it can be without going into a decimal. (cos(e^2) will be a transcendental number like Pi).
Sep 09, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
7,854 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
