Question about Vehicle Parts & Accessories
How do you put Prestige APS-200 in valet mode?
  • 139 Answers
Turn on the ignition key than press and hold the valet button until the LED illuminated steady. You are now in valet mode. To turn off valet mode, just press and release the valet button with the ignition on.
Posted on Jan 17, 2013
2 Suggested Answers
  • 11 Answers
SOURCE: how to put the prestige aps25ch 1200 foot range in valet mode
ALRMM SHOULDN'T GO OFF IN STORMY WEATHER UNLESS U GOT A LEAK SOMEWHERE OR YOUR SENSOR IS TO SENSITIVE
Posted on Jul 26, 2010
Aps51 won't learn tach
Never heard of an APS 51, Prestige Remote Starter.There is a APS 57. If it is a 57 then yes.
Jan 24, 2014 | Prestige Remote Start
I have a prestige aps 901 I just replaced the car batterie now the remote start will start the engine but imediatly shuts off what needs to be reprogramed?
check the fuse and relay to the remote start if not that then it might be the module itself if it is aftermarket it was probable shorted out when battery was changer and may need a new one
Jan 23, 2014 | APS-901 Prestige Remote Start
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
How to disable or reset a Prestige car alarm. Purchased a used car with an after market Prestige alarm installed. Alarm somehow tripped and shut off the ability to start the car. I can't find a valet...
The valet switch,on the newer Prestige alarms, is a push button LED or, it's incorporated into the antenna. In both cases, turn the key to the on position, then press and release the valet switch. The alarm will respond with two chirps confirming that it is disarmed. You may now start the vehicle. After you successfully disarmed the alarm, turn the key to on position, press and hold the valet switch for approximately 5 seconds, the LED will come on solid. Turn the key off.The alarm is now in valet. You can take it out of valet in the same manner.
Oct 28, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
How to put the prestige aps25ch 1200 foot range in valet mode
Jul 04, 2010 | Toyota Vehicle Parts & Accessories
The alarm wont let my car start. i turn the key and now response. how do i get the engune out of sleep
look for your valet switch. It should be under the dash(a little red button). put the key in the ignition, turn all the way until the instrument cluster lights on, then press on the valet switch for a couple of seconds until you hear the alarm chirp. You're now in valet mode and it should be ok to start the cart.
Oct 28, 2009 | Audiovox Prestige Code Alarm Remote Alarm...
How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Jun 14, 2009 | APS20B Prestige Keyless Remote Alarm
The car arms but the alarm does not chirp
try turning your key on and flip the valet switch, your alarm is most likely in valet mode (youll know cause the led stays on) if that doesnt work, turn the key on and off then toggle thye valet switch 3x and that'll turn off silent mode. Good luck, Martin @ lessco electronics
Feb 25, 2009 | Car APS25CH Prestige 2 Button Remote...
Problem with prestige platinum car remote starter and security system model aps-995a
FIND THE VALET SWITCH OPEN THE IGN PRESS AND HOLD THE VALET FOR 2 SECONDS THE LED SHOULD TURN ON FOR VALET MODE AND OFF FOR ALARM MODE
Jan 20, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
397 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
