I bought two CDJ 800 mk2's from the US and
I bought two CDJ 800 mk2's from the US and obviously the voltage is different over here, i plugged them in with just a plug adapter and blew both fuses, now the fuses are replaced, can i use them with a standard Step Down Converter as there is no switch to alternate between different voltages? Or do they need to go through some sort of service? Thanks
  • 33 Answers
SOURCE: Plugged cdj-800 and mixer into a European outlet-now they won't turn on
ok, remove screw under the cd mixer and slide down carefully the top of the cdj and then trace where the power cord connects in to circuit(there is a fuse there try to change anew one..thats is!
Posted on Aug 14, 2008
djproaudio
  • 515 Answers
SOURCE: CDJ 800 not working due to Voltage Selector?
What do you mean you changed the voltage? Why would you think this would work? What were the voltage settings originally, and what did you change them to?
If you had too much feedback or distortion, your gain was probably too high, or you had the recording volume on your PC set too high. This has NOTHING to do with voltage. The voltage setting on these units is strictly for 120V or 220V use. Meaning, it can be uses just about anywhere. If your unit is not working, it's because you probably fried the power on it. Are you in Europe, and you tried to set it down to 110/120V? If so, you surely fried it.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
freetek
  • 5568 Answers
SOURCE: i bought a pioneer cdj
Replacing the electronics may cure it but the drive motor may also be damaged and many Japanese manufacturers don't maintain parts stock very long so these may not even be available unless this model is still in production.
If you were willing to replace these, ask for the 220/50 Hz parts so you won't need a step-down transformer or have to worry about line frequency. The US has 60 Hz while most of the world uses 50 Hz line frequency.
Posted on Aug 04, 2009
  • 32 Answers
SOURCE: Hi i bought my technics 1210mk5's in america and
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Posted on Jun 10, 2010
SOURCE: hello i need some help,i
You can have a fuse problem only in you plug it diectly to 240V, the UK voltage. Check that the converter is a step down transformer, 240 to 110 volts. The system should work with 110Volts. If everything is ok, then you blew the system´s powersupply with the 240Volts. that is difficult to solve.
Posted on Dec 09, 2010
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
Hello i need some help,i have pioneer 800 mk2 cdj i buy from usa but im live in london so difirent pawer supply here i bought the converter but try connect and its not showing nothing maybe the problem...
Dec 08, 2010 | Pioneer CDJ-800MK2 Turntable
Fried unit, european plug
Pls check fuse of ur Cdj's
djajay
Apr 13, 2010 | Pioneer CDJ-800 Turntable
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
I have plugged it in with a uk adapter but its not
US has different voltage to UK. You need a step down transformer in order to get the correct UK voltage.
Dec 14, 2009 | Nintendo DS Lite Console
I bought pioneer cdj's 200 in the USA. Unfortunately it was used in SA without a correct adapter. I think it blew my cdj's because the 210 adapter was not used. Is there anyway i can fix them?
u could have bloo the trancformer,but check the fuse inside the unit first, & the plug coz u never know unless u test it.
if it still doesnt work then the trancformers probobly gone.
http://www.donberg.ie/warehs/groupbe.htm
Aug 04, 2009 | Pioneer CDJ-800 Turntable
I bought two cdj 800 from the usa and they wont power up
nothing to do with hz.adjust country voltage&turn ON
Jul 05, 2009 | Pioneer CDJ-800 Turntable
My play pause cue button has worn out on my cdj 800 1
No, the cue buttons for the CDJ800 and CDJ800MK2 are configured differently, and will not fit. You can take your existing buttons off, take them to a body shop, and have them dip it in chrome!
Hope this helps some.
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Mar 23, 2009 | Pioneer CDJ-800 Turntable
- OPTiC
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Dec 27, 2008 | Pioneer CDJ-800 Turntable
32 people viewed this question
 Grubhead
Grubhead
