Question about Artec e+48u Flatbed Scanner
Artec scanner error message code:-704, media (adaptive equipment like adf, tma, and film holder) not available
We hooked this scanner up to our desktop and it will scan via the flatbed with no problems. Today I am trying to scan slides using the drawer and get the above error message.
4 Suggested Answers
  • 243 Answers
SOURCE: can't find driver for may scanner artec e+48u
You can find your drver on download.com once you are on the web site search by procut number (e+48u) not model.
Posted on Jan 06, 2010
yammy_alf
  • 666 Answers
SOURCE: Artec e+48u scanner problem
go to control panel, under device manager uninstall imaging device (scanner) and click scan for hardware changes, if found new hardware occurred click next and choose no, not this time tab / choose install from the list specific location option tab / choose don't search i will choose the driver to install / click show compatible hardware tabs and select scanner type appeared.
Posted on Mar 23, 2010
fanaudi
  • 1381 Answers
SOURCE: I have a old Artec
Hi ,
Try from here :http://members.driverguide.com/driver/detail.php?driverid=123132
If you are under W7 , there is no more driver available and the only way to get your device running would be to install a virtual version of W XP on your HDD , if you don't want to buy a new scanner .
Regards .
Posted on Jan 01, 2011
TMA doesn't work ;code 22
If 22 is blinking in the Scanner LCDThe Transparent Materials Adapter (TMA) may be attached incorrectly or is broken.
  1. Disconnect the scanner power cord.
  2. Disconnect the TMA cord from the scanner.
  3. Verify there are no bent or broken pins in the cord plug of the TMA. If the cord has bent or broken pins, it will be necessary to contact HP .
  4. Reconnect the TMA cord to the scanner.
  5. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  6. Check that the TMA is properly positioned on the scanner glass; either reposition the TMA in the positioning plate or reposition the positioning plate on the scanner glass.
  7. Reconnect the power cord to the scanner.
  8. Attempt to scan.
If 22 "The scanner could not scan" displays on the screen and the Transparent Materials Adapter (TMA) is being used
  5. Reconnect the power cord to the scanner.
  6. Perform a self-test on the TMA. Click here for instructions to do a self-test on the TMA (bps05670) .
  7. Attempt to scan.
  8. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
If 22 "The Scanner could not scan" displays on the screen and the TMA is not being used
  1. Disconnect both the scanner power cord and the USB cable.
  2. Perform a self-test on the scanner if it has a built in self-test. Click here for instructions on performing a scanner self-test (c00030441) .
  3. If the scanner passes the self-test, reconnect the USB cable and attempt to scan. If the scanner fails the self-test, it will be necessary to contact HP.
  4. If the scanner still does not function, follow the instructions for resolving USB initialization and related communication errors (bps03850) .
May 05, 2012 | HP 4570C Flatbed Scanner
I have a Coolscan IV with the coolscan 3 Software, and i have a mac book pro. The following message appears: Error "Could not send look up tables to scanner.", Please help me
Try upgrading to v4.02 driver. You may need to download 4.0 first as 4.02 may only upgrade from 4.0. The scanner runs with v4.02 on my Mackbook pro but I can only scan using the slide adapter and the film holder at present. The film adapter will not work but i'm not sure if this is a hardware or software problem.
Apr 06, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Error code 122
Code -704 Scanner Microtek i800
Sep 30, 2010 | Microtek ScanMaker i800 Film Scanner
No error message displayed when film jams
Take it into nikon specialty shop for a service.
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
I WANT TO KNOW THE MEAN OF ''ERROR 06'' IN HP SCANJET 8270 AND THE POSIBLE SOLUTIONS... THANKS
If LCD displays Error 06 or Error 09 , the TMA might require service
Press SCAN PICTUREc00068011.jpg button once (see Figure 3 above). The TMA lamp should turn on (see Figure 4 above). If pressed a second time, the TMA lamp turns off (if TMA is detected). NOTE: The scanner carriage lamp should be off when the TMA lamp is on and should be on when the TMA lamp is off. The only time the TMA could not be detected is if the accessory cable is not plugged into scanner
Jul 02, 2009 | Office Equipment & Supplies
I am looking for instructions on this product.
Step 1: Open the scanner lid and remove the Transparent Materials Adapter (TMA).
Step 2: Place your slides or negatives into the appropriate template. Follow the orientation indicated by the icons on the template.
Step 3: Tip: If you are scanning fewer than the maximum number of negatives with the TMA, cover the empty spaces with the provided light shields to avoid letting any extra light in
Step 4: Place the template on the scanner glass, aligning the arrow on the template with the indicated mark on the scanner bed.
Step 5: Close the scanner lid and press the Scan Film button (or select the Scan Film option if you're using the HP Solution Center application on your PC).
Step 6: In the Scanning from dialog box, click Change Settings.
Step 7: Under Scan Shortcut Settings, select your Scan Type (either Negatives (TMA) or Slides or Positives (TMA)).
Step 8: Under Scan To select Save to file. Then click Scan.
Step 9: Under the Save Location dialog box, click Browse and enter the destination folder of your choice. Click OK and follow any on-screen instructions to finish scanning. The scan will be sent to the destination folder you selected. s.gif s.gif
May 01, 2009 | Office Equipment & Supplies
Where do i put the negative to scan on hp g3010 scanner
On the lid there are thin plastic rails that frame two 35mm Negatives. Place the film in that holder, framing what you wish.
Check HP's site for the owners manual for advanced settings for your specific model to get the best results from your Negative or as HP calls it Transparent Materials Adapter (TMA)
Let us know
Good luck
Apr 14, 2009 | HP Scanjetâ„¢ G3010 Flatbed Scanner
How do I make photos from slides
Scanning slides is a tricky thing, because the light comes from the wrong side. What you would need is a flatbed TMA (Transparent Media Adapter, sometimes called a film adapter).
This is basically a lamp in the lid (or a replacement lid) of a scanner, to allow it to scan film. The film is placed on the scanner glass bed, but instead of being illuminated by reflected light from below like a print, this lamp shines down through, from behind the film. Then everything else pretty much works the same, we scan film using the same basics as for prints.(source)
You can give it a shot at a high resolution (1200dpi+) and see if that gets acceptable results.
I personally was never satisfied with my scanner, so I just went to a photo shop and let them do it for me.
Dec 30, 2008 | HP Photosmart C4580 All-in-One InkJet...
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
Artec e+48u Flatbed Scanner Logo
120 people viewed this question
Top Artec Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Artec Office Equipment and Supply Expert? Answer questions, earn points and help others
