Code to control original Bose 3.2.1
I have just bought a Thompson Top Up+ box and need the code to program the Thompsom remote. I have looked all over to find the Bose code but haven't had any luck.
Hope you can help,
DC
  • 15 more comments
  • david990 Jan 24, 2009
    Bose 3.2.1 Home entertainment System, purchased Dec03.
    Thomson DTI6300 Top Up TV+Digital TV Recorder
    I am after the Bose code so I can program the Thomson remote to control the volume and mute on the Bose.
    Thanks
    Many thanks for the links Ginko,
    Still no luck, even the all for one site did not seem to have a Bose code.
    DC
    Four digit Bose 321 remote code?
    The Thomson remote is URC60230R00-00
    3RC16c-1124. There are no instructions for a manual search.
    I do not have a Bose Advanced Remote so cannot use the Bose to control my PVR.
    DC
    No AT&T or mode button. I have tried all the codes and they all are invalid.
    dc
    I do not have an ADVANCED controller and I am not trying to program the Bose controller. My Bose controller is unable to be programmed.
    Many thanks but the manual does not refer to my controller.
    Thanks Jack,
    The remote that comes with the Thomson PVR is capable of controlling the volume and mute of your TV. I would just like to be able to control the Bose volume and mute. Seems like the Bose code is a major secret:-)
    dc
    Hello maklean,
    I have tried all the codes with no luck.
    Many thanks,
    dc
    chetangupta
    Rank: Wiz
    Rating: 80%, 20 votes
    check manual or manufacture website
    I have already checked the manual & the website. Both Bose & Thomson.
    Thats why I'm here,
    dc
    I have contacted the seller, they only know the list that is published with the manual.
    This does not have any Bose codes.
    Guru, I have tried all the codes you posted without any luck,
    dc
    Mr Mark52,
    Unable to follow the instuctions as my remote does not have the same buttons (aux1).
    Thanks,
    dc
    pappal,
    I need the Bose code not the thomson's codes.
    Even so I tried all the codes you gave with no luck.
    Thanks, dc
    Boyzid,
    I DO NOT WANT THE CODES FOR DAEWOO!!!!
    dc
    MNfisherman,
    I am trying to put a Bose code into the Thomson
    remote, I do not want to use or buy another Bose remote. The Bose remote must have a code number?
    dc
    early1234,
    Tried 1377 no luck, just finished speaking to Bose they say it should be thomson?
    dc
    Hello drumbanger,
    Yes, I've tried remote.com
    Thanks,
    dc
    Many thanks for all your help, I will look at a new universal remote.
    All the best,
    dc
  • 716 Answers
The Remote Will Not Control The Bose Unit You Will Need Another Universal Remote That Is Equipped With A dvd Function Button.
Posted on Jan 24, 2009
    Genius:
  • 1,199 Answers
Did you try here www.remotes.com
  • 871 Answers
Try 1377. if this stil wont work,
Call the Bose 800 number which can be found on the http://owners.bose.com website.
hope this helps you in anyway...
  • earl norman llanera
    earl norman llanera Jan 24, 2009
    have you tried 1377?
    we,l, i think its a very big secret for whats the code is...
  • 81 Answers
Codes pour Daewoo 003 009 051 058 094 115 191 245
  • 139 Answers
Check manual or manufacture website
    Genius:
  • 1,665 Answers
Hope This lot helps you out
0067,0463,1938,0586,0473,1067,0517,0193,0659,0039,0379, 0265,0546,0207,0065,0041,0238,0385,0075,0102,0225,0066,0221,0247,0365,0384,0774,0401,& 0574
Good Luck .....
  • 11,896 Answers
If the 3 digit code is not known then an additional facility allows you to input a 4 digit manufacturer's code which then allows you to step through all codes held for that manufacturer until the correct code is identified.
The very newest TV receiver codes may not be stored in memory and it will not be until the next update of the remote's memory that these TV receivers can be controlled by the remote.
I WILL DOSOME MORE SEARCHING FOR YOUR PRECISE CODE
  • 6 more comments
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    1110
    0115, 0265,
    0292, 0455,
    0607, 0711,
    0713, 0853,
    1012, 1046,
    1291, 1900
    To control the cable/satellite box
    1. Turn on both the 3•2•1 system and your
    cable/satellite box.
    2. Press and hold the
    Program
    and
    Guide
    buttons (shown on the left) for 3 seconds.
    The remote source buttons will light to
    signal that you have entered programming
    mode.
    3. Use the number keys to enter your cable/
    satellite box’s four-digit setup code.
    4. Press
    Program
    once to complete programming.
    The remote will flash once to indicate
    successful programming. To confirm that,
    use the remote to change cable/satellite
    channels.
    Note:
    If your advanced remote flashes rapidly
    several times during programming, an error has
    occurred. Wait 7 seconds for the remote to clear
    and begin programming again
  • Nate Stansfield
    Give SAT code 1377 a try
  • Nate Stansfield
    IF YOU CANNOT FIND A CODE YOU CAN AUTOPROGRAM YOUR REMOTE TO AUTOMATICALLY FIND THE CODE
    1. Turn on the device.
    2. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
    AUX) until the mode keys blink twice. For example, to search for a TV code, press
    and hold SELECT and TV at the same time.
    3. Press 9 9 1. The mode key you selected in step 2 blinks twice.
    4. Point the remote toward the device, and press . The remote automatically tests
    each code in its library, beginning with the most common codes. The mode key
    blinks once each time the remote transmits a new code. The mode key blinks twice
    when it reaches the last code.
    5. As soon as the device powers off, press SELECT.
    6. Verify the new code is correct by pressing POWER.
    7. Did the device power on again?
    • If yes, press SELECT to assign the code.
    • If no, complete the following steps:
    a) Turn the device on.
    b) Press or to step forward or back to the correct code.
    c) When the device turns off, press SELECT to assign the code.
    8. Go to Which Code Worked to identify the code that controls your device. After you
    identify the code, record the code in the space provided on the cover of this guide.
  • Nate Stansfield
  • Nate Stansfield
    NOW THAT YOUR REMOTE IS PROGRAMMED AND WORKING FOR YOUR DEVICE, You can find what code was actually use by following these steps;
    Finding the Code That Worked
    (Program Code 9 9 0)
    1. Press and hold SELECT and the appropriate mode key (CBL, TV, VCR, DVD, or
    AUX) until all mode keys blink twice.
    2. Press 9 9 0. The mode key you selected in step 1 blinks twice.
    3. Press 1; then, count the number of times the mode key blinks. The number of blinks
    indicates the first digit in the code. For example, 4 blinks indicates the first digit in
    the code is 4. If the mode key does not blink, the digit is 0.
    4. Press 2; then, count the number of times the mode key blinks. This number indicates
    the second number in the code.
    5. Press 3; then, count the number of times the mode key blinks. This number indicates
    the third number in the code.
    6. Press 4; then, count the number of times the mode key blinks. This number indicates
    the fourth number in the code.
    Note: After all four numbers in the code are identified, all mode keys blink three
    times.
    7. Record the code in the space provided on the cover of this guide. You may need it
    again if the device code is accidentally erased.
  • Nate Stansfield
    IF YOU TRIED THIS AUTOPROGRAMMING THAT I MENTIONED AND IT DOESN'T WORK THEN IT WILL NEVER WORK.
    Auto programming bypasses manual code entry. If your remote cant find the codes, that you remote isn't made to work with that device.
  • Nate Stansfield
    you can try purchasing the LATEST bose remote. Most bose remotes do not work with thompson top boxes
  • Nate Stansfield
    AS STATED BEFORE, your remote will not work for this.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Try this,
1. Release the volume controls and assign them to the AUX:
A. Press and hold AT&T Button and OK Button at the same time, release both buttons. All the mode keys will flash twice indicating you're in programming mode.
B. Enter 955 on the remote keypad, the AT&T key will flash twice indicating a correct entry
C. Press the mode key you want to alway receive the volume commands - I assigned mine to the AUX mode button. The mode key chosen will flash three times indicating success. Volume commands will now be delivered to the AUX button regardless of the mode you are in. 2. Assign the AUX to the BOSE system: A. Make sure the Boze remote receiver is powered on (green light is on). B. Press and hold the AUX Button and OK Button at the same time, release both Buttons. All the mode keys will flash twice indicating you're in programming mode. C. Enter the 4 digit BOSE code on the keypad, I used BOSE Remote Code 4000.
D. The AUX Button will flash three times indicating correct entry.
  • yashan.co.in Jan 24, 2009
    try this
    this is for thomson 0115, 0265,0292, 0455,0607, 0711,0713, 0853,1012, 1046,1291, 1900,0794
    President:
  • 1,214 Answers
You may have to do a manual search for it. You didn't give the model number of remote your working with, but most all Thompson remotes have a manual search function.
  • Mark Egan Jan 24, 2009
    Get this remote manual, and follow the instructions. The Thomson remote manual code entry process is pretty much the same for all their remotes.
    http://66.77.167.109/rcaaccessories/Rcaa...
    Substitute "Aux1" in the directions with the button you want to control the Bose.
  • 19,396 Answers
  • 350 Answers
What is the Make & Model of the Bose?
What do you mean by Thompson Top Up+ box?
Bose has an awesome site @ http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/contact/index.jsp
Click on the http link above to go there.
or call them directly @
Within the US
Call 1-800-905-2138 (For the Aviation Headset X™, call 1-800-233-4416)
To provide you the best possible service, please have your product nearby when you call.
I hope this is helpful.
Good Luck!
Code to control original Bose 3.2.1 - 3221045.jpg Jack
  • Jack Iaria
    Jack Iaria Jan 24, 2009
    I'm sorry to hear that your having trouble getting the code for your new remote purchase!
    When I buy top of the line electronics with remotes I start to lose it when they don't work!
    I recently bought a Digital Cable Box from my TV & Internet provider COMCAST then after wearing out the button for last channel viewed I started to lose it. I called COMCAST and told them what had happened and they said "Bring it in and we will give you a new one FREE!. I could hardly believe my ears but it was true!
    I now believe that all universal remotes are not universal!
    Why....because I believe that a simple remote can steal technology from any piece of electronics it gets the code from!
    My point is....
    If you love your electronic and need a remote get one from the manufacturer!
    I HOPE this is helpful.
    Good Luck!
    Jack
  • Jack Iaria
    Dear FixYa Premium Guaranteed Answer Customer:
    Yes, sadly I believe some high end MANUFACTURERS OF ELECTRONIC EQUIPMENT KEEP THEIR CODES TOP SECRET!
    If you believe your ELECTRONIC EQUIPMENT is the best then I'd just scrape that UNIVERSAL REMOTE CONTROL you just bought, go to YOUR ELECTRONIC EQUIPMENTS' MANUFACTURERS' WEBSITE, and buy a new one directly from the Manufacturer!
    I'd swallow my pride, accept the loss, and get down to getting down with my electronics! But that's just me!
    Hope this is helpful.
    Good Luck!
    Jack iaria
    Brigadier General:
  • 8,619 Answers
Hi
I need a Verizon Fios code to work Bose Solo 5 TV sound speaker.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Feb 18, 2017 | Bose Televison & Video
Hi, I'm having trouble to get the volume to work on a Bose LS50 system. I'm using a Harmony 880 and an Audio Authority C-1024 to convert the IR to RF for the Bose.
Try by setting the remote control with an other set-up code said for your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Nov 10, 2016 | Bose Televison & Video
Can I use my BT youview remote to control my Bose solo,if so what is the code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
Feb 27, 2016 | Bose Solo TV sound system - Black
I have a bose universal cineomate solo 2 and I need the remote control code for my starview 7 digital cable recevier
About 66,600 results (0.76 seconds) Search Results
    STARVIEW HELP FILES ' AfterDawn Discussion Forums
    forums.afterdawn.com > ... > Home theater > Digital TV - UK & Europe
    Jul 6, 2007 - 11 posts - ‎3 authors
    Posting codes to the forums is no longer allowed. ... Connect your box and PC with a Null modem cable and switch on the cable ... 7. One of the listed ports should indicate which port your USB adapter is .... Using this method my Starview indicated it scanned 56/56 ... go to parental control in receiver menu Starview box
    Jun 15, 2014
    All New Starview HD Combo unit
    Nov 1, 2009
    STARVIEW UPDATING FIRMWARE - NO CODE ...
    May 14, 2008
    More results from forums.afterdawn.com
    Looking for a Universal Remote Control code (4-digit) to ...
    nordstromchicago.com/Looking_for_a_Universal_Remote_Control_cod...
    ... digital cable terminal? I need to reprogram my cable remote to operate my digital cable terminal. ... Code for Hugh button universal to control Dion free view box ... read more ..... I need the remote code for starview 7 remote control? Trying to ...
    Phantom Digital Cable TV Receiver. - TechKings
    www.techkings.org > ... > General Cable TV. > Phantom
Jan 28, 2016 | Bose Televison & Video
Need a remote for a Bose wave music system
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Bose Televison & Video
I need to link my bose cinematic remote to the ilink ir 210 sat box, but I cant find the right code.
28970,28934,28944. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 14, 2015 | Bose Televison & Video
PROGRAMMING THE REMOTE TO SOUNDDOCK
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter". Setup proceedings to Bose brand remote controls are described in detail. Setup code list also is given.
Visit this site too.
Apr 18, 2013 | Bose New Original SOUNDDOCK SERIES II...
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Thompson DTR remote codes
Try these two codes the first worked for me 1368 or 1994 best of luck
Nick
Nov 14, 2009 | Televison & Video
Bose remote device code for directv satellite box
im living in st maarten nederlands antillies on the dutchside and i boutgh a sitilite box in newyork i ask the people if that can work in ST.Maarten they said yes but ST.MAARTEN is dish network i cant find the code program for the box that box is direct plus hd dvr directv satilite reciever. please can you help me.
Dec 01, 2008 | Bose 3 2 1 GSX System
Televison & Video Logo
1,151 people viewed this question
Top Televison & Video Experts
Electro Med Services...
