Sky codes for technosonic 32'' lcd tv
I am trying to enter code into my sky remote (rev4) so i can use it to switch on tv volume etc tried several codes but to no avail television is a technosonic LCD 3201
  • 3422 Answers
SOURCE: Code to enable volume on remote control
HI,
Can you please give the make and model no. of your remote?
Posted on Sep 13, 2008
SOURCE: Code for RC
Thanks to coolguy008 my problem has been resolved thankyou
Posted on Sep 14, 2008
SOURCE: BOUGHT SAMSUNG LE40A656 LCD CAN,T GET SKY REMOTE TO WORK
I tried the closest model no. in the Sky list in the system setup, I think the code was 0840. Cover the front of the remote and press TV, then press red & select button until the remote led light blinks twice, key in the code 0840 and then press select.  Try the volume button and this should work.  If you get stuck go into interactive and system setup and select setup of sky remote and it gives you a list of makes and models, this is the closed one to the LE40A656 and works with mine.
Hope this works for you.
Posted on Jan 28, 2009
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Posted on May 01, 2009
SOURCE: universal reote control code fot technosonic t v lcd 3201
i have lost remot .but bought universal remot dont know wat is code ?
Posted on Sep 24, 2009
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
Cant find right code for my sky remote for 42lh2000
I have just purchased a LG 42LH2000 Tv but can't seem to get my Sky Plus control to work the volume does anyone have a code to help
Jun 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
Sky remote volume button not workin tv volume.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0000
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Sep 09, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sky remote codes for lg32lh4000
Hello Rubel
TV
TV
0056
cheers
Little Dish Fitter
Aug 20, 2009 | LG 32LG30 32 in. LCD HDTV
Cannot find code to program sky remote control
TV
TV
0156
cheers
Little Dish Fitter
Mar 12, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I had the same problem but eventually solved it
I fixed the problem I had with Sky remote control not working with my new TV Model 32LG3000 but I had to update my remote to a (rev8) as the code did not work with my old remote which was a (rev4) the code was 0056
Jan 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Hyundai 32" tft lcd tv. model no.hlt 3270
I don't know if these codes will work but the Hyundai ones we use are code 1272 or 0662.
To put the code in:
Press TV
Press and hold Select & Red until the LED blinks twice
Put in the first code above
press Select
then try the volume buttons, if that doesn't work do exactly the same sequence but try the second code, if neither work let me know and I'll try and find another code for you
Jul 30, 2008 | Hyundai HPT-4250 Television
Televison & Video Logo
275 people viewed this question
Top Televison & Video Experts
