Question about Frigidaire FTF530FS Front Load Washer
Atf7000fso frigidaire broken door hinge. door sags
  • Official Brand Answer
  • 4,342 Answers
Hello Scarlet Newman - If you are referring to the bushings hinge door, the part number is 134550800 for the MSRP of $51.62. Part can be purchased directly from the manufacturer or through a part distributor (part number may be different). However, since it will need to be installed by a professional I strongly suggest a proper diagnoses first to verify which is the correct part that needs replacing.
Posted on Jan 17, 2013
  • Scarlet Newman Jan 17, 2013
    The local appliance people would charge about $350 to repair this. They suggested I buy the parts including a "sag kit" which I understand is basically a washer and find a local handyman to put it in. Here is a photo of the area that is failing. Thanks, Scarlet
How do a fix a Westinghouse fridge door that has dropped slightly
Hinge screws probably loose. Refrigerator doors have hinges screwed on the outside. The hinges allow for you to move door to be level, loosen screws, move door level and hold it there till you tighten screws. Sometimes the hinges are covered with a plastic piece that you pry gently up on to remove.
Jul 03, 2016 | Westinghouse Refrigerators
Frigidaire microwave door is sagging
Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Aug 10, 2015 | Frigidaire Microwave Ovens
My Frigidaire microwave door is sagging and about to fall off
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
Apr 24, 2015 | Frigidaire Model PLMVZ169GC Microwave Oven
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Apr 01, 2015 | Frigidaire Microwave Ovens
How do i align my frigidaire front loading washer door?
Thank you for your post, friend!
I understand that you're asking how to align the front door of your Frigidaire washer. I would recommend having a professional come out to your appliance, some of these intricate parts do require precision and patience. I hope this is helpful. -Matt
Sep 07, 2014 | Frigidaire Washing Machines
Door is sagging and causing it to not work properly
Hey friend, thank you for the post!
I understand that your Frigidaire microwave door is sagging and your appliance is not working properly. You could need to a new door or hinges. These intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Aug 17, 2014 | Frigidaire PLMV168 Microwave Oven
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Frigidaire FTF530FS Front Load Washer Logo
129 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
