Question about LG W2243T-PF Monitor
W2243t need to install driver - LG W2243T-PF Monitor
    Guru:
  • 198 Answers
This monitor is only plug n play.
Posted on Jan 15, 2013
How to install driver
The looks of this monitor its just a plug n play but using the Internet to find drivers for it is okay.. Only if you find drivers from LG then you can install them.. But normally if you are connected to the Internet you will be informed that there is a driver for this product in the windows update... but at the moment no drivers so it seems as looked over.
Jan 15, 2013 | LG W2243T-PF Monitor
I have a LG W2243 monitor and Windows Vista. Every time I change the monitor settings blue screen crash, also can not set the native resolution.
For help on the Blue screen of Death see my tip here: http://www.fixya.com/support/r6836997-blue_screen_death
Judging by the fact that you get the BSoD every time you change monitor settings I suggest that you should update your video drivers.
Jun 08, 2011 | LG W2243T-PF Monitor
The screen when powered ON shows vertical colored lines from top to bottom. what can i do to resolve this?
Problem 1-cause from monitor or graphic card
Either the monitor is going bad or the video card is going bad. If you can get your hands on a spare monitor, try swapping it out and see if the lines are still there. If they are, then the problem is with the video card. You'll want to replace the video card if that is the case.
Solution-
Try restart your pc in safe mode. It will disable vga mode. If you are using pci-e card(external graphic card), try to change using internal graphic card to check wether that problem is cause from graphic memory problem.If your motherboard have internal memory, then you can change using internal memory. If your motherboard dont have it, that you need to buy new external memory.Before that, you can try clean and clear using eraser, to clean dirty at gold contact .
example link to follow.
Problem 2-cause from ram module
Ram modules can also cause vertical lines on a monitor.It's hard to believe but i have experienced it multiple times.The ram is detected by the system,yet the display is corrupt.If you open up the pc and touch the ram modules the lines go away.This is very rare yet a possible cause and easily overlooked.
Solution:
Same like memory graphic. Link
Try clean the dirty. Or if it cause from overheating, try using fan for ram.
Problem 3-overheating in graphic card
The video card could be over heating which causes what you are seeing, lines can also be called "Artifacts". Try opening the side of your case and see if you see these lines. Also, it could be a driver issue, try cleaning out your drivers using Driver Cleaner, and reinstalling the appropriate drivers.
If you have another computer, if the video card is a expansion video card (Meaning you have it in a PCI/AGP/PCI-E slot) try it in another computer to see if the problem persists, if so your card is probably bad and needs to be replaced.
Solution:
For this problem, actually, i try using fan.
 Absolutely is solve the problem. i'm added internal fan, modified it for to cool graphic (PCI-E). fOR THIS CASE, mostly the problem you face is your pc will restart, or suddenly your screen became white. However, you can try.
Problem 4-magnet radiation
Also check to see if there are any magnets near the screen or hard drive.
For this, make your screen like rainbow. and sometimes, it make your screen, showing the line and it also will cause problem with your pixel in screen/ monitor
video in youtube for vertical line solution
May 25, 2011 | LG W2243T-PF Monitor
How do I adjust image so it fills the screen, side to side and to bottom?
Using the buttons on the screen, bring up the menu.
Then using up/down or left/right buttons navigate to a picture that show a squre that has arrows showing to increase screen size in the approite direction. Select this picture and use the arrows to either increase or decrease size.
Your timeous rating of this solution is much appriciated.
Thanks
Nov 01, 2010 | LG W2243T-PF Monitor
My monitor goes into power save mode and wont come out of it? my pc turns on and i see the monitor display the picture but then goes into power save mode and i cant get out of it.
Tr it with other PC first to make sure it is not video card problem. If it is monitor problem, then you should read my guides to see if you will want to DIY repair.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 22, 2010 | LG W2243T-PF Monitor
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
I can't install my driver
all the latest motherboards needs to install the UAA driver first, you might have not installed the UAA driver first you need to install this UAA driver and then try to install the audio driver ...
if you tell me your exact motherboard model i can assist specifically regarding your motherboard ...
but if you have not installed the UAA driver then install and try to install the audio driver you will not get any errors after that like previously ...
regards
-Dileep
Dec 26, 2008 | Computers & Internet
LG W2243T-PF Monitor Logo
128 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
