Question about Garden
Stihl FS 55 will not shut off
Will not shut off when button is pressed
    Sergeant:
  • 322 Answers
I have seen the wire work itself or break off the ignition module and I have replaced several of the actual kill switches. Check the wires from the switch to the ignition module first and if they are good go to your local STIHL dealer and ask for the switch. The switch part number is 4229 430 0203
Posted on Jan 16, 2013
rwvanlue
  • 486 Answers
SOURCE: I am trying to rebuild my Stihl FS-55 weedeater.
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
1) Determine that there is spark?
2) Have you used a type of spark tester?
3) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug,
it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel
cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 22, 2009
mowerman1857
  • 389 Answers
SOURCE: Stihl FS 55 will not start
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
Posted on Sep 16, 2009
Dolfoff
  • 148 Answers
SOURCE: stihl fs 45 ignition problem no spark
Disconnect the small spade terminal wires from the coil itself and test for spark. If you do not have spark replace coil. If you do have spark check those small wires for insulation damage and grounding. If wires are OK check kill switch.
NOTE: DO NOT START MACHINE with small wires unplugged! Only test for spark.
Posted on Sep 26, 2009
rwvanlue
  • 486 Answers
SOURCE: how do i set the carburetor on a Stihl FS-55
Over the past 8 years, the FS55 has had at least 5 different carburetors, and they have at least 3 different systems with different adjustments. Many of them do not have much of an adjustment and will not cure running problems. If you are experiencing poor running conditions, I would suggest some basic checks first. The spark arrestor screen is a big culprit on this model.
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Posted on Nov 23, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Stihl repair manuals where can I find them
repair manuals maybe thru a dealer . but it won't be free
Aug 20, 2014 | Stihl String Trimmer Brushcutter Service...
Trying to recoil a spring on start rope on a FS 55
No but you have to be very careful not to let spring go. curve on spring should match up with molded curve on the housing.
Oct 02, 2013 | Garden
Need Stihl FS55 parts diagram. Thanks!
Standard carb settings for stihl equipment: screw both needles in, then turn anit-clockwise L- 1 full turn H-3/4 of a turn.
Aug 11, 2012 | Garden
Sep 06, 2009 | Garden
Garden Logo
322 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
