I`ve acer aspire 7250G and have a Blackscreen after BIOS update. After the update the system start booting but the screen is black. i`ve push 45 sec power i removed the battery and for this time happend to the charging cable to reset the BIOS but there is nothing. I have Blackscreen still.
  • Computers & ... Master
  • 17,115 Answers
Does ANYTHING show up on the screen AT ALL
Posted on Jan 16, 2013
leecom72
  • 4806 Answers
SOURCE: Acer Aspire 4315 BIOS Recovery
Hi there.
After using killcmos you should have updated the bios straight away, this is because you have wiped all the bios settings. As soon as you restarted the laptop you effectively killed the computer, getting it recovered can now prove near impossible. The only option you have left now is to locate the bios battery, remove it for an hour to see if the bios resets, other than that Acer may be able to help.
Good luck and thanks for using FixYa!!
Posted on Mar 12, 2009
tat4u
  • 520 Answers
SOURCE: acer aspire 5610 wont boot windows XP
turn on pc enter bios setup select default settings save and restart.have os disk in drive wait for screen display any key to start from cd.press any key to load disk.in options select install windows ( not repair) your system will find existing os ,now you can choose repair or install fresh copy.if you choose to install fresh copy delete partition first and create new partition and format.
Posted on Mar 02, 2008
  • 400 Answers
SOURCE: No power acer aspire 5310
Sir,
It seems to me that your Processor of the Laptop has got effected to and unbalance current supply. As you know that replace processor would work i would suggest you to claim its waranty before replacing new processor.
Posted on Aug 31, 2009
Geekman
  • 32281 Answers
SOURCE: acer aspire 5336 black screen...when i turn on the paltop the acer logo comes on and it boots up , while it is booting up the screen goes black, i can barley see the icons on screen underneath..if i
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jul 27, 2012
  • 18 Answers
SOURCE: Bios reset on a acer aspire 1640z
To reset the bios in a laptop you need to unplug the power supply and remove the battery. Once you do that press and hold the power button for 45 seconds then put the battery back on and plug it in and then try starting it. Everything in the bios will be reset to the factory.
Good Luck
Posted on May 04, 2009
Can't do a system restore
Please contact acer and ask for operating system disk.
Jul 07, 2013 | Acer Aspire Computers & Internet
My Acer laptop will not boot up.
You may have a corrupted video driver due to an update. For some Acers, press and hold F10 when starting the computer. Two beeps will mean that the bios settings have been restored and the machine may boot correctly. If you can enter the BIOS via F2, F1, F10, ESC or DEL, then find the area for display and change it to low resolution then save and restart your computer. Once running, you will need to uninstall the current video driver and have the computer install a new one.
Mar 18, 2017 | Acer Aspire 5736z 4460 Laptop
Acer aspire 5336 black screen...when i turn on the paltop the acer logo comes on and it boots up , while it is booting up the screen goes black, i can barley see the icons on screen underneath..if i...
Jul 26, 2012 | Acer Aspire One PC Notebook
Blackscreen on start up
Welcome to fixya,
Acer Blank screen at startup My Acer Aspire One notebook goes to a blank screen at startup.
BIOS Recovery Systemkat107x130.jpg As awful as it sounds, this is a fairly common problem with Acer Aspire notebooks and it sounds like you have an issue with the BIOS - as long as you can see the power button and hear the fans running to indicate that it is not a power issue. Luckily, these notebooks come with a built-in BIOS recovery system that should get you up and running without damaging or losing any of your files. Know that doing this may void your warranty, so if you have a warranty, you should talk to Acer directly. Follow these steps EXACTLY, and it should work for you:
  1. Format a USB memory stick to FAT. Make sure it is bootable.
  2. Download the latest BIOS from the Acer website. Follow these links for BIOS for Aspire One 150 or this link for BIOS for Aspire One 110
  3. Put the FLASHIT.EXE and the BIOS file in the root directory of the memory stick.
  4. Rename the BIOS file: ZG5IA32.FD. It is important that you get the file name exactly right.
  5. Remove the drive.
  6. Turn the Acer off, but make sure you have a working battery and AC power connected.
  7. Insert the USB memory stick into a USB port.
  8. Press Fn+Esc and press the Power button at the same time. After a few seconds, release Fn+Esc.
  9. The power button should be blinking. Press it once.
  10. At this point, the BIOS will flash - don't press anything or interrupt this process. If you've done it right, the power button will stop flashing and the notebook will reboot. When it is all done, everything should be set to reboot.
Because you have an Acer Aspire One and you are getting the blank boot screen, I'm betting that this will solve your problem. If you are still having problems after following these directions exactly, then let us know and we can try to troubleshoot hardware or screen issues that may be the culprit.
Hope this helps.
Dec 18, 2010 | Acer Computers & Internet
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
My friend acer aspire one cant open and becomes blacked screen...
Take out the battery,unplug the power cord,and hold down the power button for 30-45 seconds,Then put the battery back in,plug the power cord back in and start the computer.
Jul 30, 2009 | Acer Computer AOA150 Notebook
Good Luck
May 04, 2009 | Acer Aspire 1640Z Notebook
Acer aspire 5610 wont boot windows XP
Mar 02, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
521 people viewed this question
David Payne
David Payne
