Question about JVC KD-AVX33 Car Video Player
No Display without pressing on the front
When i connect the front to my avx33, sometimes the display stays black, then when i press the front it comes up, when i go over a bump, it goes black again, music keeps on playing.
I think something doenst make good contact, so i opened the front, theres a brass plate which is pressed in when connecting to the headunit, could it be that this brass doesnt make good connection? can this be the problem why i have a black display??
anyone?
  • chollie Feb 03, 2009
    tried that with contactspray, no luck..... thanks anyway, someone told me it could be the spring wich is holding the faceplate, ill check if the spring is rotten........
    Scholar:
  • 116 Answers
Absolutly "could" be the problem. Try using a q-tip with rubbing alcohol on it and GENTLY clean all contacts. Replace the face and see if tere is an improvement.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
5557.led-status.png-
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
Why is my screen black?
SONY CUSTOMER SERVICE:
800-430-4433
Press 5, then 0, then 0
Average Wait: 10 mins - Mon-Fri 9:00am-8:00pm ET
Sony Repair or Exchanges
1-888-222-7669
FROM WHAT I HAVE BEEN READING THIS WAS A RECALL A COUPLE YEARS BACK BUT NO LONGER.
Aug 05, 2012 | Sony Cyber-shot DSC-S730 Digital Camera
THE BLACK DOES NOT PRINT. ON MY HP C7250
First of all, I hate to say this but, be sure you are using a genuine HP 02 black cartridge. Refilled / re-manufactured cartridges can cause damage to the printheads because their formulas are sometimes too acidic.1) Press the SETUP button on the front panel by the display. 2) press the DOWN arrow until "Tools" is highlighted on the display and then press the OK button 3) Arrow down again until you see "Clean Printheads" and press OK again. 3) After cleaning, press Setup again.. Arrow down to "Print Report" and press OK. 4) Arrow down to "Self-test Report and hit OK again. Your printer will print out another page. If the black ink is flowing on the self-test page but yet not when u are using the computer, then there's got to be some software problem on the computer itslelf. If it still doesn't print from the black printhead the we usually have either a print head failure or an IDS (Ink Delivery System) failure.
Jul 21, 2010 | HP Photosmart C7250 All-In-One Thermal...
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
EO ERROR ON DISPLAY
Hello sir; There requir reset as following steps;
open front door, cheat the front door interlock switch, then use paper clip press the service switch through the acess hole located on the left above the fuser unit, you will see "$" sign display, press "*" twice , screen will no display, select 4 press OK, enter 01 press OK again, touch "cancel" to return to menu.
Oct 01, 2009 | Canon PC-920 Black and White Copier
SGI F180 Flat Panel Display no longer turns on.
If the power button does not stay on, the monitor might be burned out.
Aug 20, 2009 | SGI Silicon Graphics Silicon Graphics F180...
JVC KD-AVX33 pairing problem
To inicialize to factory settings do: In "Setup" menu go to "others" menu, go to "Initialize" press "Enter".
With this you will loss all your customized settings
Sep 25, 2008 | JVC KD-AVX33 Car Video Player
Brand new Toshiba Satellite L305D-S5868 laptop display screen has gone black, even though the computer is on.
Since your laptop is brand new , you may not be familure with it's function keys , FN
Sometimes the users accidentaly presses the FN and the F5 monitor function key at the same time.
which effectively turns the notebooks display off.
D in the image below is the FN function key
and the monitor function key could be F5 , it will have a little monitor symbol on it.
When they are pressed together it will turn the notebooks display off and enable any VGA monitor connected to it's VGA ports. when pressed again , they will turn of the VGA port and turn on the notebooks display.
Thank you for using FixYa!
Az.
Sep 18, 2008 | Computers & Internet
JVC KD-AVX33 Car Video Player Logo
183 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
