Sound noise feedback during recording
Noise feedback occurs some 7 to 10 seconds into recording using Windows Vista Business
  • 27,725 Answers
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Posted on Jan 16, 2013
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Sound noise feeback during recording
b>
Jan 15, 2013 | Logitech Webcam
Feedback sound like wind noise in right headphone of QC3, starts quietly and gradually gains in strength. Sometimes disappears, then comes back again. No sign of moisture in battery compartment. Any ideas?
The design of these headphones includes a microphone on the outside and on the inside of each earcup. The outside microphone detects outside noise. The inside microphone monitors what you are hearing and when it detects that the outside noise is present inside, the active noise-canceling circuits remove that noise. This happens fast enough that you perceive a siginficant reduction in the outside noise getting to your ears.
The airspace inside the lower half of the earcup is a tuned chamber defined by the foam in the ear cushion. This is important because with the inside microphone in close proximity, but at a 90-degree angle to the speaker, the circuit must be designed to eliminate the normal feedback that occurs. When the foam has weakened or deteriorated to the point that the size and shape of the chamber cannot be maintained, more of the speaker sound is directed toward the microphone than the design can compensate for causing audio feedback to occur. This also happens when the lower half of the ear cushion is compressed. Since this is occuring during normal use,
it may be time to replace the ear cushions. They are available from Bose for $35 per pair.
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_earcushionkit_acc.jsp
Sep 18, 2009 | Bose QuietComfort 3 Acoustic Noise...
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
Logitech Notebook Quickcam (SOUND PROBLEM)
Normal 0 If you have your speakers turned up to high it will give you feedback causing distortion and static. Sometimes even awith the speakers turned down low, feedback is possible.
I recommend using a headset when videoing. Hope this is of some help. Bud
Apr 22, 2009 | Logitech QuickCam Webcam
Burner does not finalize discs
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
APPLIES TO
  • Windows Vista Ultimate
  • Windows Vista Starter
  • Windows Vista Home Premium
  • Windows Vista Home Basic
  • Windows Vista Enterprise
  • Windows Vista Business 64-bit Edition
  • Windows Vista Ultimate 64-bit Edition
  • Windows Vista Home Premium 64-bit Edition
  • Windows Vista Home Basic 64-bit Edition
  • Windows Vista Enterprise 64-bit Edition
After you install Windows Vista on a computer that uses an SiI Parallel Advanced Technology Attachment (PATA) chip from Silicon Image, the computer does not recognize an attached optical drive as a drive that supports recording. Therefore, you cannot use the computer to burn CDs or DVDs.
This problem occurs because the SCSIport driver does not populate the correct number of bytes for an IOCTL_STORAGE_QUERY_PROPERTY Request Packet (IRP) when the device does not return a correct serial number.
Service pack information loadTOCNode(2, 'resolution'); To resolve this problem, obtain the latest service pack for Windows Vista or download the following Hotfix.
Microsoft Hotfix http://www.microsoft.com/downloads/details.aspx?FamilyId=2E692102-D483-44B0-BBFF-FA87AE019CBE&displaylang=en
Please rate this a fixya
Feb 01, 2009 | Microsoft Windows Media Player
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Dec 15, 2008 | Dell Inspiron 1521 Notebook
Echo suppression
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 08, 2008 | Logitech Quickcam Ultra Vision Webcam
Acer orbicam camera
Install sound driver for VISTA.
That should fix it.
May 24, 2008 | Acer Aspire 4720 Notebook
Sound Interference
NO it dosent sound like there related problems at all. Now you say you get interferance or is it more like a static noise only when using the dvd player??? If thats the case then you have an output device problem as its breaking down and crackling into your input to your sound amp or the tv. Its a problem that will need to be traced with a scope and a test disk. as it could be a D to a converter or an op amp IC, or even as simple as a filter cap. Good Luck
Apr 10, 2006 | JVC DRM10 DVD Recorder
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
