Question about Kenmore 2942 400 3.2 cu. ft. Top Load Washing Machine
The washer tub is bonceing all over - Kenmore 2942 400 3.2 cu. ft. Top Load Washing Machine
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Its out of balance you need to even disperse the weight of clothes based on how wet they will be when the washer goes into the spin cycle. The solution is to open the washer and move items in the washer to the spin cycle stays level.
Posted on Jan 15, 2013
The washer tub is completly loose
BAD THRUST WASHER IN TUB OR MORE LIKELY BAD MOTOR COUPLER, WORSE YET TUB BEARINGS?
Apr 18, 2014 | Frigidaire ATF6000ES Front Load Washer
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Washing Machines
Leaks from underneath
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Sep 30, 2012 | Kenmore Elite Washing Machines
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Water leaks from the machine tub while it is in the wash cycle or turned off with water in the tub. I can empty the tub using the spin cycle without any leaking
you have bad tub seals. is there stains on the walls inside the washer and the water is leaking in the middle bottom of the tub?if the washer is old get a new washer,did one last week but the washer was in good condition it was close to 300 bucks.you have to pull the agitator,remove the top ring,with a spanning tool you need to remove the center parts and pull the inner and outer tubs and the three nuts and bolts holding the outside tub on and replace the two pieces in the middle it's a bearing and a seal kit,but you need the tools to do it,like i said if the washer is old replace it or call someone in to do the job for you
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
My 660r when i go full throttle it sounds like it bonces of the rev
If it's hitting the rev limiter before the red-line you need to have the ECU recalibrated or install a power commander.
Oct 09, 2009 | 2008 Suzuki GSX-R 600
The water will not drain out of the washer
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 22, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore 2942 400 3.2 cu. ft. Top Load Washing Machine Logo
69 people viewed this question
fordexpert
Mike Squire
Robert Rankin
