Very low sound after new needle installed
I installed a new needle on the turntable, as there was none when I bought this at a flea market. Radio works/sounds great. Switching to phono, it plays and I hear the music very, VERY low. From other questions, it appears I need to hook up a phono input? No idea what that is or how to. Wouldn't this console stereo already have that? Any help would be greatly appreciated. Thanks!
  • Audio Player... Master
  • 5,056 Answers
Firstly the cartridge could be faulty or incorectly wired. I think what you are refering to is a magnetic cartridge pre-amp. If the turnatable has seperate audio connectors these should be plugged into the "phono" socket. And not an "aux" or "CD" input. If there is no phono socket, you wouldn't be able to plug a pre-amp in anyway. Yes the deck if it is built in should have this pre-amp built in. However these pre-amp can fail!
To test if the pre-amp is working, even if has no phono socket, unclip the leads to the cartridge. With your amp on, touch the end of each wire with your finger. On two you should hear a buzz - one for each channel. If it's not loud then there's a problem with the pre-amp. If you do get a decent buzz the cartridge is faulty.
You can also trace the wiring to the pre-amp inside the unit, if you wish to fix it. It will almost certainly end up at an IC, which should be replaced.
Posted on Jan 16, 2013
techman
  • 3130 Answers
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Posted on Jun 15, 2007
landsend
  • 1066 Answers
SOURCE: Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Posted on Mar 21, 2009
SOURCE: Replace needle on old Admiral turntable
what type of needle does a gemini turntable need?
Posted on Jun 30, 2009
Ganx
  • 113 Answers
SOURCE: I just inherited an old Zenith console turntable
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Posted on Jul 25, 2009
  • 124 Answers
SOURCE: Record player - sound only plays out of one speaker
Your tracking and anti-skate are not set correctly.
If you have the manual for this unit, it should have directions for setting these.
Posted on Sep 12, 2009
Why won't our arm on our record player advance to play record on auto control? Lifts, moves back and returns to original position.
Try adjusting the counterweight on the back. Average weight setting is 1 gram. most high end RPs have it and it's a 'turn clockwise to increase' deal.
If it's a cheapo, there may be something interfering with the arm. possible a spiderweb inside! or??
Aug 17, 2014 | Audio Players & Recorders
RCA VLP37H needle arm won't advance to play record...moves backward, then seats down again
You will probably have to take the bottom off to see what is happening inside. The thing could have been tampered with by someone try to fix something. So it's not something that you know was previously working. With a bit of luck it might need a bit of grease to get it going. But you never know with a second hand model!
Speakers Stopped Working
yes!!! this is common on these!!! they leak from the lugage racks!!! you have to buy new speakers!!! but, you don't have tombuy them from the dealer, to expensive. i bought mine from a flea market that sells alot of radio stuff!!! works better than new!!! hope this helps ya!!!
Nov 29, 2013 | 2003 Chevrolet Tahoe
I bought a Super nes console from a flea market and it doesn't work at all no lighting up no nothing.
Well sometimes at flea markets there are crooks that sell crappy itmens then they say that it
works and is fine but really its not so you have gotten ripped off so you should buy a new one from a reputable seller then.
Apr 04, 2011 | Nintendo Super NES Console
Sound quality is terrible on my Crosley CR79 turntable. Sounds very tinny and terrible. Got a new needle and the problem still exists.
This could be an earth lead to the cartridge problem, or the cartridge itself. Check the connections.
Feb 07, 2010 | Crosley 0187SST Turntable
Forgive me for not knowing what any of these parts are really called. My friend just shipped me an NAD 533 turntable & when I received it the cover was cracked and the hinges broken, the round weight...
My suggestion to you, if you really need a turntable is to find one at a flea market, since the ones you currently find in the market are "professional" quality, and are very expensive. The same applies to the stylus (needle). The reason they give you when you ask why: They are somewhat of an oddity nowadays, after CDs, DVDs, and now Bluray!
Dec 02, 2009 | NAD 533 Turntable
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
I bought a used 2003 Jetta for my daughter with only 12,000 miles on it. The Monsoon radio suddenly stopped working. The display shows FM 88.1 (the radio staion) but there is no sound and the radio is...
I have come to find out that in the 90's auto makers started installing factory amplifiers in their cars so they could use low wattage stereos in the dash. It's usually a blue wire off the stereo that runs the amp, maybe it couldve become disconnected? I also know that even if you put in an after market stereo, this wire must be hooked up or you'll get no sound from the speakers. hope this helps.
May 26, 2009 | 2003 Volkswagen Jetta TDI
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Apr 01, 2009 | Crosley Audio Players & Recorders
Old Turntable Philips
You may have a bad stylus (needle), it can cause just that type of problem. Find a service center near you and see if they can get a replacement for you. They are very easy to replace, but very difficult to find.
Hope this helps.
Dave
Jun 30, 2008 | Audio Players & Recorders
56 people viewed this question
 Grubhead
Grubhead
