Irulu 10.1 tablet will not turn on. was working fine it is only 2 weeks old. when plugged in the light just flashes red and green. Please help
SOURCE: red power light flashing but no picture
Ditto for Jan 13th with a Panasonic 50"!
Posted on Jan 14, 2008
  • 187 Answers
SOURCE: panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
Posted on May 30, 2009
  • 80 Answers
SOURCE: 7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Posted on Aug 31, 2009
  • 148 Answers
SOURCE: Sharp Aquos LC30HV4U stopped working
You are in luck!..The units poowerboard is overheating and since you have it taken apart already this is the fix for you!...Check the popped capacitors in the metal box you find on the back of the actual screen inside the unit...This is a very common problem,m so I've helped many this way and wrote a general post on the how to's of diagnosing and repairing the problem, follow these steps and your tv ill be good as new for less than $5.00 before feb 5 th!! :P...Here it goes (please rate if this works out :D).....................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped anyone (or not) then please rate, thank you!
Posted on Feb 03, 2010
I found my old IRulu AL101 in my closet and i plugged it in but all its doing is showing a red light
let it rest in the charger overnight, the battery has become so low it needs a firm charge first to be able to work again might be working after charging it for 1 hour even but i would still let it charge overnight..:)
Jun 02, 2016 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Can't find camera flash on off
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 24 posts - ‎21 authors
Real 1G DDR3 Nand Flash 8GB Camera 0.3MPixels-Front Android ... Can't find apps as downloadable to such as ad card anywhere in google play. ..... Problem is, every time i reboot the tablet or the device is off then turned ... Irulu AX101 stuck on Irulu connecting my world, how ...
Sep 20, 2015
How do I change the camera view on an irulu tablet?
Apr 13, 2015
How do I keep my Irulu from turning on randomly?
Sep 30, 2014
Problems switching from front camera to back camera
May 13, 2014
More results from forums.androidcentral.com
How to find your Chinese Tablet firmwar
Dec 21, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
My Irulu 10" tablet will not turn on. I turned it off list night and today it will not turn on. I left it charging last night.
Try holding down power button for 10-15 seconds. If that doesn't work, try holding down up or down vol with power button at same time until screen comes on then release both.
Mar 04, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
There is a red and green light on my irulu tablet when charging and wont turn on
Some tablet you have to hold the powe'd button for at least five seconds.If that don't work it's dead.
Jan 16, 2015 | Tablets & eReaders
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
How do I fix my blank screen on my irulu tablet???
drain the battery then power cycle Unplug electric then hold power button in for 30 seconds, then reboot. If that doesn't work might be a lcd issue.
Sherri allinonecomputer.com
Nov 25, 2014 | Irulu 9 inch Android Tablet PC, 4.2.2...
Irulu 7 instruction manual?
i cant get my wi-fi work on my irulu tablet help please
Aug 19, 2012 | Irulu 4g 7"google Android 2.3 Touchscreen...
Hi, About 3-4 weeks ago I replaced the bulb on my
I am having the same problem as mg2low. I changed the lamp, but my Sony KF60WE610 still will not turn on. It flashes green several times then it begins to flash red. Can you recommend some trouble-shooting for me? Thanks, Richard
Sep 05, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
