Question about Schumacher & Fast Charge Starter Charger
I have a Schumacher XP2260 starterr and need fuse size
My charger is fully charged as the light indicates when I put it on the charger, but when I turn the knob to start my car it is blank, not turning on. When I push the charge indicater it shows 100%. but I think either the knob is not catching or the fuse might be blown. the other components work (air gauge and light, and car adapter) but why won't it turn on when I turn the switch to start my car?
  • Cindy Hester Jan 17, 2013
    We fixed it ourselves, It was the switch which melted, so we by passed it by adding another switch (actually a wall light switch to the outside). It is rigged but it works!
    BTW.. for the lady that answered the phone at Schumacher, it DOES have a fuse inside, but that wasn't what was wrong anyway.
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
SOURCE: i have a Schumacher WM-10000A speedcharger and need fuse size
The fuse is a 12.5 Amp 250 V Fuse. I have the same charger and I think mine is toast. Replaced the fuse and it blew.
Posted on Nov 22, 2009
  • 509 Answers
SOURCE: I borrowed a friends and don't know how to read
the meter goes down as it's charging.
Posted on Jan 03, 2010
SOURCE: schumacher SC7500A DOES NOT WORK
Check the fuse.
Posted on Feb 07, 2010
c1apton15
  • 3400 Answers
SOURCE: I purchased a Schumacher 1200A battery charger a
I don't think you did anything wrong. I think your battery is tired and can't take a charge deep enough as it used to. As batteries get older and after repeated discharge and recharge during normal operation, they start losing their ability to hold charge as deep as when new. This is gradual and after a couple of years they drop to 50% and less. I think your attempt was "gallant" and you did everything correct, but it sounds that battery has flatlined on you and "Doc, the patient is gone"
Posted on Jan 05, 2011
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Kindle not working. It will not turn on blank screen
Make sure that the kindle is fully charged. When charging the kindle 3 will have a yellow light indicating that it is charging. When this turns green, your kindle is fully charged. Make sure your kindle is fully charged and then try turning it back on.
Feb 21, 2011 | Amazon Kindle DX 3rd Generation
When the charger is left plugged into the electrical outlet, will it automatically turn off when fully charged?
when the battery is fuly charged if im not mistaken the green light will still stay on but will not be charging the battery anymore. All the light is doing is indicating that the battery is fully charged. It is not recommended that you leave the battery sitting on the charger for long periods of time since batteries an get a memory from a charger and then you might start having some battery issues. Hope this helps.
Dec 10, 2010 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Peg perego 12v charger question
The green light means it is ready to use. If the battery is bad though, the light will still be green.
Mar 07, 2009 | Peg Perego 12 Volt Rechargeable Battery
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Schumacher & Fast Charge Starter Charger  Logo
473 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
