Question about Blaupunkt Car Audio & Video
My car radio turns itself on
The radio in my Fiat Panda 2006 turns it self on. Sometimes it even turns on when the car is standing in the parking lot and I am not there. I has also turned on while I was driving. When I turn the radio off by pushing the off button, it still (sometimes) turns on when I start the car. The problem seems to happen more often now that it is cold and snowing (?). One battery died from this, so please help.
  • Tony Fuff Apr 19, 2013
    My 2004 panda does the same and the battery goes flat.
3 Suggested Answers
  • 3 Answers
SOURCE: JVC KD-LHX500 has power, but won't turn on!
Replace the 15 amp spade fuse in the back of the unit. See if that get you going again. If that doesn't do it then check your wirin Black goes to ground, Yellow is a constant hot, Red is a hot trough the fuse box, Blue is for your power antenna if you have one, the Orange with a White Stripe is to the Illumination and is also hot.
Posted on Nov 12, 2008
dmfixit
  • 226 Answers
SOURCE: 2000 Mitsubishi Mirage DE dies when idling
with the battery fully charged try scraping the positive over the terminal on the battery and see if it sparks like a draw is sucking out amps if theres no draw on the battery it wont spark at all (good) if it sparks (bad) you have something grounded and killing your battery.. gl
Posted on Jan 06, 2009
How do i check level and drain if required the auto transmission fluid on a 2006 fiat panda dynamic as a warning light on dash states clutch overheating?
on most transmissions the fill plug is a square hole or a allen type located on the side of the transmission case about halfway, that is where you check and fill the transmission, and to drain it the plug is on the bottom of the transmission case.
Nov 18, 2016 | Fiat Cars & Trucks
Wheel change on a Fiat panda
Great car i saw it on top gear lol. To change a tire, you will need a car jack, lug wrench, and a spare tire. Just put the lug wrench on the bolts and spin away. Make sure that you undo the bolts in a "x" pattern.
Jul 29, 2016 | 2006 Fiat Panda 1.2
Clutch pedal
Check the fluids in both those places. The power steering and the clutch are both hydraulic.
Nov 25, 2013 | Cars & Trucks
2005 fiat panda shows keylock on dash
a panda ,makes a change from the americans and their jugonauts,but iam confused here as to what code your putting in as these nice little motors never have many problems with the electrics unlike my pennance the renault in fact their very good these little pandas with very little going wrong even if the timing belt breaks the valves clear the pistons -these cars are ideal shoping trolleys and easy to park .Anyway back to question what code are you putting in here the radio code ?
Dec 28, 2012 | Fiat Cars & Trucks
WILL NOT TURN OVER, TOTALLY DEAD. A FEW LIGHTS FLASHING ON INSTRUMENT PANEL, INTERIOR LIGHT WEAK. NO NOTHING. HAVE JUST INSTALLED NEW BATTERY WITH NO RESULTS. PLEASE ADVISE. FIAT PANDA DIESEL MULTIJET...
Are the battery terminals clean and are your battery leads not damaged in any way. Remove both battery cables and hold the terminals in boiling water for a while, make sure that there is no build-up of scale inside the terminals, then reinstall them, making sure that they seat properly and are tightened. (All your symptoms point to a weak battery or a poor connection).
Jan 30, 2011 | Fiat 124 Cars & Trucks
I was about to help a lady friend change the oil filter on a Fiat Panda 1100cc petrol engine but on lifting the bonnet I could not locate it. I checked with the Car hand book which made no reference to its...
did you ever find the location of the oil filter? a local auto shop sold me a filter for my wifes Panda 1.1l active. However, when it came time to do the oil change I found myself searching the internet for answers also.
William G.
May 23, 2010 | 2007 Fiat Pininfarina
Trouble removing the engine cover from Fiat panda 2006 diesel
i guess you got a chip then, look at the cover ithink 3 or 4, circles, fine screw driver and pop em out to see the 10mm nuts.
Aug 15, 2009 | 2006 Fiat 124
Car Audio & Video Logo
468 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
