Question about Brother MFC 7840W Printer
Where is corona wire - Brother MFC 7840W Printer
    New Friend:
    Problem Solver:
  • 5 Answers
Corona wire. Remove the toner cartridge with the drum. In the back of the drum you will se a green button on the right side. To clean it, slide it to the left and right several times and park on right hand side. Reinstall.
Posted on Jan 25, 2013
How to clean corona wire on brother 7840W
Corona wires are in the drum cartridge, small screen or grid over them. usually there is a colored slide that you can move back and forth to clean coronas.
Jul 23, 2014 | Brother MFC 7840W Printer
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Describe your how to clean the corona wire on hplaserjet 3050 Problem
Laserjet 3050 does not use corona wires. HP uses a PCR roller which applies the charge to the drum unit. HP stopped using corona wires on most units years ago. What print problem are you having that makes you think that you need to clean the corona wire?
May 01, 2011 | Office Equipment & Supplies
I HAVE A SHARP SF 2314 COPIER,I CLEANED THE GRIDY FOR MAIN CORONA WIRE NOW THE MACHINE PRINT BLANK;I USE MATHILETED SPIRIT.HOW CAN I SOLVE THIS PROBLEM?
MYA BE THE CORONA WIRE WAS SNAPPED AND IN ORDER TO PRINT YOU HAVE TO ASEMMBLED NEW CORONA WIRE.IF YOU WANT CKLEANED THE CORONA WIRE , JUST USE DRY CLOTH ,NOT WET IT WITH ANYTHING
Mar 25, 2010 | Sharp SF 2314 Copier
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Looking for corona wife for brother 8860dn MFD.
Try to get some corona wire stock which was quite common back in the day and install it in your drum.
Aug 14, 2009 | Brother MFC-8860DN Printer
Cleaning the drum unit corona
Message is telling me that the drum is dusty. It says to clean the corona with the wire. I don't know what the corona is and I cannot find a wire that might help me know how to clean the corona
Aug 18, 2008 | Brother Office Equipment & Supplies
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Brother MFC 7840W Printer Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
