Question about NATURES MIRACLE Jaw Pooper Scoop - Jumbo
I need replacement springs for the large scooper. Where do I get them?
Should I need to buy a ****** scooper or should depend on a waste removal service for removing dog waste?
According to me it\'s better to buy any pooper scooper. Depending on any service center may charge you high and you have to wait for them till they arrives for cleaning. If you buy any efficient pooper scooper for dog you can dispose waste without handling with your hand and it will be much easier.
Dec 30, 2013 | Pets - Others
What are the methods adopted to clean up dog stool?
Best available method is to scoop the poop instantly using an automatic pooper scooper. I usually use a pooper scooper to clean up my dogs stool and deposit it in a garbage box or dispose it safely as dog stool if remained in open ground is found to cause harmful effects.
Oct 29, 2013 | Pets - Others
What size scooper do I use when making cupcakes?
I use a scooper that holds 1.33 ounces. This is around a medium size. It fills up the cupcake tray 3/4 way full.
Jan 14, 2013 | Home
Are there ****** scoopers for high grass?
Basically what you need is a scooper with claws that can lift the **** of the grass without making a mess. Check out this link: http://www.pet-dog-cat-supply-store.com/shop/index.php?page=shop-flypage-22717
May 15, 2012 | Pets - Others
Seems that starter is not engaging, battery is charged checked all grounds that i know of and all the bike does is click at starter
The large contacts in your starter may be burned and need replacing. There is a 5-sided plate on the back of your starter that is held on by three 3mm allen head bolts. Remove these three bolts and take the plate off. Behind the plate is a plunger and spring. There is a short spring on the outer end of the plunger and a longer spring on the inner end. Pull the plunger out. Look into the solenoid and you'll see two large copper contacts. If they look burned, you need to replace them. It's easily done and you can usually change them without pulling the starter off. You need a 14mm wrench since the starter is made in Japan. Before you start working on the starter, disconnect the negative battery cable.
Good Luck
Steve
Jun 21, 2011 | Harley Davidson XL Sportster 883...
1999 hyundai elantra how to replace rear struts
Rear struts usually have a large bolt on the bottom and 3 little bolts on top, to allow removal.
But then you need special spring compressor clamps to take the tension off the coil spring, so that the top of the strut can be safely removed. Careful, because the springs can be very dangerous.
You remove the top from the strut by undoing the large center nut. If the shaft turns with the nut, use a small wrench on the flats in the end of the shaft. Once the top is off, then you remove the spring. The strut tube then has a cap retaining the insert cartridge that needs to be removed and replaced with a new one. Reverse the rest.
Dec 21, 2010 | Hyundai Elantra Cars & Trucks
Spring can't be replace
if springs are inside the legs remove large nut and springs slide out,if external,remove large nuts,undo pinch bolts at bottom yoke,pull tubes out of yokes
Jul 03, 2010 | 1998 Suzuki VZ 800 Marauder
Aficio 2035 S/P: toner leak
Four things to look for here.....
1. Did you remove the inner top of the toner bottle? The clear one. That will create a mess. Only remove the black cap.
2. The seal between the toner hopper and the top of the photoconductor unit has been damaged. Need to replace or fix this. You can see the seal around the hole in the pcu when you pull the toner hopper out.
3. The claws in the toner hopper that grab the top of the toner bottle are bound up or the release mechanism (green handle area) is messed up. Clean if you can or replace worn parts.
4. If the copies are getting light, then the plastic 'scoopers' inside of the toner hopper are damaged. You will need to disassemble the receptacle the toner bottle fits into and repair the 'scoopers'. If they are still there, just glue them back on.
Sep 15, 2009 | Ricoh Aficio 1018D Copier
How do you adjust the height of the front suspension on a 2007 1100 v star? mine bottoms out when stopping or bumpy roads.
Height is not adjustable on those. Your only option would to replace the springs in the forks with a higher rate spring, and get better valving to slow down the jounce of the bike.
May 31, 2009 | 2005 Yamaha V Star Silverado
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
NATURES MIRACLE Jaw Pooper Scoop - Jumbo Logo
202 people viewed this question
Top NATURES MIRACLE Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a NATURES MIRACLE Pets - Other Expert? Answer questions, earn points and help others
