Question about Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50
Hotpoint FZA50 Freezer not cold enough
Hi, our FZA50 upright freezer is not maintaining a cool enough temperature. Meat etc. is still frozen but ice cream is soft. What can I check? The thermostat is set to nearly max, there is good ventilation, but I do notice that the fan seems to be running continuosly (it stops when the door is opened and resumes on closing).
  • 1 more comment
  • Patrick O'Farrell Jul 11, 2007
    I emptied the freezer last night and transferred to a chest one we have in the garage. A bit of ice in the bottom, so its now nplugged and I'll clean in at the back of it tonight once its defrosted. Hopefully that'll do it.
  • icecool Dec 04, 2007
    The fan is making a lot of noise and now the high temperature light is coming on once a day, food is frozen ok. Have removed draws and noted a build up of ice which i have removed.
  • Anonymous Mar 29, 2014
    Hi I have this very difficult problem with my fridge.
    Every time we buy meat, we pack it in the bags, keep them for hour or two in the fridge to cool and then put in the drawers.Before i could put 6KGs at once and it would be super easy, but for the last 2 years i need to put a 2 bags , then the freezer would start cooling up from -18 towards -13, then the ****** beepers starts, its usually late at night... Then i have to press superfrost for an hour and then repress it and pray it would not cool to -6.It comes to -8,then its like this for a day!!!AND THEN it resumes rapidly to designated temperature.This 2 bags literaly ******* my other stuff since the freezer "heats" up 10deg to level the temperature..Any clues
  • 72 Answers
Try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Posted on Jul 11, 2007
SOURCE:
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 13, 2012 | Freezers
High temp light on, loss of door suction, ice in channels in back pannel of freezer, Why is autofefrost not working? Have to leave empty for 2-3 days to defrost.
The defrost heater element has failed, it has created so much ice buildup on the cores air can not draw through the chanels in the cooling plate, should not be that expensive to repair.
Regards Russ
Dont forget to vote and if you need any more help, Email me at wgheaven@yahoo.com.au
May 07, 2011 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
I have a Frigidaire upright freezer model# ffu20f9gw3. The temperature alarm light is on. Cold air is blowing but the ice cream melted, and the hot dogs are still frozen and loaves of bread that i...
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Aug 13, 2010 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer is not getting cold enough. For example, meat is still frozen but ice cream is soft.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 01, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Red light on not cold enouth
The red light bis indicating that the temp is too high, if you can ,turn the thermostat to a colder setting, if this makes no difference, then you have a serious problem, you will have to call an engineer.
Plz rate this solution,
Thanks.
Dec 06, 2008 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Condensation on base of Hotpoint R134a upright freezer
sounds as tho you have an insulation breakdown. no repair except to refoam - and that is difficult to do
Aug 09, 2008 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Hotpoint 4.87 cu. ft. / 138 liter Upright Freezer FZA50 Logo
971 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Andrew Taylor
Andrew Taylor
Thomas Perkins
Thomas Perkins
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
