Question about Garmin Approach G5 Handheld GPS Receiver
My brand new Garmin Approach G6 will not acquire a GPS signal. Is there some way to correct the problem?
  • Garmin Master
  • 3,289 Answers
All gps units need a clear view of the sky to collect enough data for a proper "fix". The less obstructions there are, the faster & more accurate the fix will be.
Initially, the first fix may take up to 20 minutes. Long acquisition times typically occur when the unit is powered up after being moved hundreds or miles or more since its last fix. This would be the case from manufacturing location in China where it was shut off to where ever you are now when you turned it on.
Acquisition times after this should be significantly less (10 - 60 seconds)
I hope this helps and good luck.
Posted on Jan 16, 2013
5 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
sharcnet
  • 2130 Answers
SOURCE: My Garmin Nuvi670 (brand New
This is not correct. This indicates that there is a problem with the satellite receiver. There should always be a number assigned to the GPS S/W version. If it returns a value of 0.0 this is a problem. If your unit is new, take it back to the store or call Garmin.
- Jim
Posted on Nov 01, 2008
  • 16 Answers
SOURCE: gps garmin nuvi 705 most of times doesnot acquire
re position antenna
Posted on Jul 10, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 650 will not acquire a satellite
Yes, this indicates that the main board can not communicate with the GPS receiver board in the flip-up antenna assembly.
Please see this link for more info:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Dec 14, 2009
Garmin approach G6 hand held yardage finder
I would say the battery is defective but make sure the charger is ok, you will need a DVOM meter to test the charger, it should have about 7-9 volts output unloaded.
Sep 22, 2016 | Garmin Approach G6 Golfing GPS
Garmin approach g6 screen frozen
do a hard reset...look in yr user manual for more clarification on how to do that.
Aug 25, 2012 | Garmin APPROACH G6 GPS
My Garmin Nuvi 3790T will not acquire a satellite signal
Does the GPS work outside of the vehicle?
Where is the GPS mounted?
If the GPS is under the dash, mounting it up on top of the dash will help.
If the Vauxhall has a windshield with a reflective metallic coating or treatment in the glass, this may result in poor GPS satellite reception.
Apr 12, 2012 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Updated unit and still acquiring satelites is showing, what can i do?
If your unit is still acquiring satellite, then it means the signal strength is weak, try to get it outside where it can be facing the sky directly so it will be able to acquire satellite. Once you just update your gps receiver, it seems like it is brand new and when it wants to first acquire satellite, it might take longer to do so. But if it has access to the sky directly, it should take about 3 to 5 minutes to acquire.
If your unit is indoor, it may not acquire satellite, even if it is close to the window, it will not, but if it is outside, then it will acquire faster.
Check if you have any protective coating on your windshield or electronic devices which interfere with the unit from receiving signal from the satellite. Try to see if your gps receiver can use an antenna, then connect one to it and your gps will acquire satellite.
Try to reset your gps first before trying any other solution for the unit.
Dec 23, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin approach 3 will not acquire a gps signal. Why?
There are many reasons for a GPS to fail to acquire signals from the satellites. You should be outdoors with a clear sky the first time you attempt to get it to work. If it's worked before, but stopped working, it may be defective. Garmin recommends many thing to do at this link:
https://support.garmin.com/faqSearch/en-US/faq/content/YyCZrQHhuf6PO6qTKdvvr9
Jun 28, 2010 | Garmin Approach G3 Handheld GPS Receiver
GPS wont aquire a satellite
    Hello there and happy new year
    If Your Unit Cannot Acquire Satellite Signals
  1. For your Garmin GPS unit to acquire the satellite signals it needs to function properly, the unit must be taken outside, away from mountains, tall buildings and heavy foliage where it can get a clear view of the sky. Keep the unit stationary for several minutes while the GPS unit acquires the necessary satellite signals.It may take several minutes for the unit to locate a good solid signal
  2. OK
  3. Hope this is very helpful please keep me posted on this ok?
    Best regards Michael
Jan 01, 2010 | Garmin MAP76 handheldS GPS Receiver
Battery replacement now ca't find satellite Garmin c320
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Approach G5 Handheld GPS Receiver Logo
3,776 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
