Question about Roper REX5635E Dryer
Manual for installation of parts
Mod # REX5634k01
I would like a manual with pictures of where the element and other heating parts should be installed.
Thank you.
Jan Rogers
11e ponte vedra court
ponte vedra beach, florida 32082
  • janrogers1 Jan 25, 2009
    My dryer is rex5634 and would like the above information. I need instructions for installation of heating parts
No, I have not solved this problem. I would like instructions on installing parts. I purchased the products but they were vague and did not address what to do with all the parts.
Posted on Jan 25, 2009
How to replace bottom heating element in whirlpool mod-GR563LXSB? this is a floor mod electric stove
In most cases you unplug it from the power, take off the back, locate the wires to the element, remove the connectors and retainer nuts, go to the front and remove the element, replace it in reverse order.
Feb 04, 2017 | Whirlpool Kitchen Ranges
I need an element for Mod: 20070106 Ser.# GA040925
You can purchase a new heating element part # 990050051 either from Masterbuilt or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/masterbuilt/
If they are still available. All of Masterbuilt's electric smokers have been plagued with electrical problems.. It's either the element or the electronic controller on the top of the smoker, that constantly fail.
Hope this helped you and thanks for choosing FixYa.
Sep 20, 2011 | Masterbuilt 20070106 Electric Smoker
Mod # MER5710AAW The small element will not heat on its own power, but when the large front element is used, the small element heats up
chances are the infinite switch failed i would replace the switch for the small burner Part #: 7403P238-60 this should fix your problem.before ordering the part just make sure all the connections ar good on the switches after removing the back panel. hope this helps
Jun 07, 2011 | Maytag Kitchen Ranges
Dryer not heating mod # 110.64652400
you may have several problems, first, check the thermal cut-off with a meter(continuity) at the side top or the heating element. if not beep or mesure "0" on the display then is bad, change it as a kit#279816 part# at Sears. if is good(it beeps) then check the heating element for ohm about 10 to 12ohms. if it reads "0" then is bad, part#279838. if is good then check continuity on the thermal fuse at the blower housing(a white 2prong part) if it not beep then change ir part#3392519. all parts at Sears Website or Sears Service Center. good luck to you.
Feb 06, 2011 | Kenmore Dryers
I need the part no# for the broiler element in my kenmore easy clean oven mod C8806002190
Check out web site "Repair Clinic.com. I just looked up your model number and found several heating elements related to that model.
Jan 14, 2010 | Ovens
It is not cleaning well--could it be my water
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
48iabna
Nov 11, 2009 | Frigidaire 24 in. FDBB840DC Stainless...
The driver seat heater just quit. all fuses are good. how do you tell if the relay is good?
Swap it with a relay you know to be good and see if it works again,pick a relay that is not important to the function of your car.
Nov 01, 2009 | 2004 Cadillac SRX
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
User manual for Maytag DE313 Series 107
(Click below for user manual)
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=RF262LXSB0&siteCd=WHRCOM
The age of your dryer I'm not sure, The elements for your dryer can be found below, go to my web-page and enter the model DE313 into search feature and you will get pictures of the parts. The element part# is Y313538 (click link below)
http://servicepartstec.blogspot.com/
If you need help, just let me know,Thanks,Sea Breeze
Mar 23, 2009 | Maytag Dryers
How do I replace a heating element for a Frigidaire Gallery Series Dryer (Mod GLEQ 332as2)?
How are you sure its the element??? Its usually not. Ill be glad to help let me know how youve checked it??
Nov 23, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
148 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
