Question about Logitech Webcam
Sound noise feeback during recording
Noise feedback begins some 7 seconds after beginning recording on Windows Vista Business model, and lasts for 15 to 20 seconds
  • Logitech Master
  • 27,725 Answers
Noise can be a big problem when trying to record into a computer. Reducing and canceling out noise using several simple techniques will help increase recording quality and increase your satisfaction with recordings. Solutions range from complete room overhauls to simple changes in the placement of the microphone and other objects in the recording.
Use a stabilized microphone to reduce vibrations. Many hand-held or headset microphones will pick up on vibrations and movements from the user. These vibrations can carry over into the recording and reduce the quality of the recording. Using a microphone stand or stationary microphone will reduce noise while recording. Mic stands will help increase recording quality and off a possible solution that requires very little financial investment. Set up a designated sound room that is set away from the rest of your home. The farther the recording area is from windows and doorways, the better. Windows allow very small amounts of noise to filter in from the outdoors and create white noise in the recording. Hang blankets on the walls around the recording station and use many rough objects in the recording room. Sound travels in waves that bounce back and forth between smooth objects. Blankets and other rough objects will help reduce sound vibrations. These additions to the recording room will reduce ambient sounds from both the room and outside the building by blocking sound waves from bouncing back and forth in the room. If you can make a considerable investment in the room, there are several acoustic products on the market than help nearly eliminate echoes and outside noises. Install software that filters out unwanted sounds and echoes. Many computer applications exist that use programs to increase the quality of recordings and reduce the ambient noise levels in a recording room. Software is used to reduce echoes and feedback in a recording studio. Several free applications can be used to achieve the desired effects when recording. A program called Audacity is one of the most effective software packages that can help reduce noise in recordings. http://audacity.sourceforge.net/ Software can also be used to reduce electronic humming and other white noise that can be picked up during a recoding session. Buy a high-quality microphone with noise and echo cancellation. One of the best investments that a recording specialist can make is a high-quality mic. The microphone itself can reduce many unwanted noises and echoes in the recording room by filtering the actual sounds that are recorded.
b>
Posted on Jan 16, 2013
Sound noise feedback during recording
b>
Jan 15, 2013 | Computers & Internet
After 4 years our washer has begun growling and grinding when water fills atbthe beginning of a new cycle. It lasts for 10 or 15 seconds and then goes away. The machine then completes the job. Is some part...
If it is making the noise just as it is filling then you need to replace the "water inlet valve". If you can post your model number I can direct you to the part you need.
Aug 03, 2011 | Kenmore Washing Machines
My operating system is windows 7, and unable to find a driver to operate my sony ICD-P320 recorder.
Sony does not support Windows 7 for this device (yet?)
However, Windows Vista uses the same driver model, so there is a good chance the Vista drivers and software work for under Windows 7, too. You may have to override some warnings from User Account Control (UAC) during install.
Jan 07, 2011 | Sony ICD-P320 Digital Voice Recorder
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 10, 2010 | Olympus VN-4100PC Digital Voice Recorder
I need Digital Wave Player soft to work with VN-480PC
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
I have just changed my laptop with windows 7 but i think i need a driver to update my olympus vn-4100pc is there one
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
SAVE to the desktop
SAVE to the desktop
Feb 21, 2010 | Olympus VN-4100PC Digital Voice Recorder
I want to download windows 7 for vista
First, I want to make sure you understand Windows 7 is an operating system just like Vista is an operating system. When you install it, you will not be using Vista again. I also STRONGLY advise you not to install it over Vista, but rather as a clean install (freshly formatted harddrive). Installing over Vista has led to numerous problems.
Second, Microsoft has not released the final version of Windows 7 and when they do, they will expect you to pay for it. In the meantime, if you want to try it out, you can download the "release candidate" version and install it, but it will cease to operate beginning March 2010 and stop altogether in June 2010. This really should be for testing only.
If you want to have the permanent version, you can buy it (no downloads) at retail stores or online beginning in October.
If you still want to try the free version of the release candidate, here's the link and instructions...
http://www.microsoft.com/windows/windows-7/get/download.aspx
Aug 08, 2009 | Microsoft Windows Vista Ultimate Edition
Driver for windows vista home premium
I have Windows Vista Home Premium. I do not have my original Olympus disc. I downloaded the driver from driver guide (http://members.driverguide.com/driver/detail.php?driverid=583812) > installed driver (in this case pencam.exe. After installing the Olympus software I hooked the USB cable up, turned on my w-10 recorder and let Windows begin it's search.
I manually pointed it to the pencam folder where it proceeded to load the drivers successfully. I am now able to transfer my files successfully. Hope this helps in some way.
Oct 17, 2007 | Olympus W-10 Digital Voice Recorder
Logitech Webcam Logo
70 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
