I m having problems setting up my new HP printer on wireless. The computer is on the wireless network and so is the printer (both blue wireless lights are on and static) but the printer software says it can't find the printer
    Problem Solver:
  • 13 Answers
No printer driver installed. If your computer cannot find the printer there is no driver. Look in windows registry to see if your printer is there, WARNING do not change anything in the registry, IE windows regedit. Start, windows directory, regedit, software. If its not there reinstall.
Posted on Jan 15, 2013
SOURCE: I Lost My HP OfficeJet V40 Software CD
go to www.hp.com and click on "Support and Drivers". Type in the name of your printer and you can download the drivers onto your new computer so your printer will work.
Posted on Apr 25, 2008
  • 93 Answers
SOURCE: how to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
Posted on May 26, 2008
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
SOURCE: Scanner not recognizing software
I also have the same error and same 2015 printer in addition to my 7210.
Anyone figure this out? HP tech level 2 support cant figure it out.
Posted on Aug 17, 2008
Morikvendi
  • 56 Answers
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
Posted on Jun 01, 2009
HP photosmart c309 printer continues to not print or will only print the header and stops printing. How do I fix it?
Network troubleshooting
If you are encountering issues using your HP Photosmart over a network, try the following steps in the order listed:
  1. Turn off the router, product, and computer, and then turn them back on in this order: router first, then the product, and finally the computer. Sometimes, cycling the power will recover a network
    communication issue.
  2. For wireless networking issues, run the Wireless Network Test from the product control panel.
    1. Press Setup.
    2. Press the down arrow button until Network is highlighted, and then press OK.
    3. Press the down arrow button until Wireless Network Test is highlighted, and then press OK.
      The Wireless Network Test prints.
    If a problem is detected, the printed test report will include recommendations that might help solve the problem. If you need to change the network settings on your product or have never run the Wireless Setup Wizard, do so now.
    Double-click the HP Solution Center icon, click Settings, click Other Settings, select Network Toolbox, and then select the Wireless Setup Wizard link.
  3. If the previous steps do not solve the problem and you have successfully installed the HP Photosmart Software on your computer, run the Network Diagnostic tool.
NOTE: The diagnostic test might prompt you to connect a USB cable between the product and your computer. Position the product and computer near each other and have a USB cable readily accessible.
To run the Network Diagnostic tool. In the Solution Center, click Settings, click Other Settings, and then click Network
Toolbox. On the Utilities tab, click Run Network Diagnostics.If you are unable to run the Network Diagnostic tool or it does not help solve the problem, check the following sections for additional information:
  1. Make sure that the computer is connected to your network
  2. Make sure that the product is connected to your network
  3. Check to see if the firewall software is blocking communication
  4. Make sure the product is online and ready
  5. Make sure the HP Device Discovery software is running
Sep 09, 2014 | HP Office Equipment & Supplies
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
My wireless printer hp deskjet 3050 is not printing the wireless blue light keeps blinking and does not go solid like it used to what do i do?
if the wireless blue light is blinking, it means it's not connected to the router or it's not communicating with it.If wireless blue light is solid ,it means it's connected to the network.
you will need to reconnect the printer to the network by using a USB cable.it will configure the wireless connection.
  1. to start the installation ,click on the start button on the computer
  2. click on programs or all programs depending on the operating system on the computer
  3. look for the HP folder and then left-click on it
  4. inside the HP folder,left-click on DESKJET 3050a or DESKJET 3050 series
  5. inside the DESKJET 3050 folder, left-click on product setup and software
  6. left-click on connect a new printer
  7. it will open up a page with options on how to connect the printer
  8. select wireless and then hit next
  9. if you are prompted to connect the usb ,please connect it
  10. if it asks you whether printer is connected to the network,select no
  11. click on next
  12. if usb is already plugged in,tick the box that says it's already plugged in
  13. hit next
  14. wait for the prompt to unplug the cable
  15. try printing wirelessly
let me know if these steps do not solve your problem.
Jul 15, 2011 | HP LaserJet 3050 All-In-One Printer
I'm trying to connect my wireless HP DeskJet 3050 printer with my computer. In the set up it said to Press the WPS button on the router. The product automatically finds the wireless network and configures...
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
Feb 10, 2011 | Arris SURFboard SBG900 Wireless Router...
My built in wireless network adapter is no longer detecting any networks. It is an hp pavilion dv 2500. Is there a way to fix this problem; do I need a new adapter? If so, where can I get one?
The new hp units have a touch switch on the top panel. It should be blue when on, otherwise it is orange/yellow. Just touch the icon to change the status from off to on, then check for networks.
The paragraph below is from the hp website on wireless unit problems:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is quite common to accidentally bump the button and turn off the wireless service. On most computers there is an LED light that glows blue when there is a wireless device is turned on and enabled.
This is the link to that site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00812738&cc=us&lc=en&dlc=en&product=3379103
Good Luck
Feb 01, 2010 | Computers & Internet
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
I can not get my HP Officejet J4680 Inkjet Printer to work on wireless. Can only use with USB cable. I no longer have my Setup CD. Any suggestions?
First check that your antivirus and firewall software are not blocking the print jobs. Do this by turning off the services for a few minutes. If you can print, check for a setup option of trusted machines. If that doesn't help, make sure you have a strong wireless signal between the computer and the printer with no interference from other appliances (cordless phones, microwaves, etc). Also check your settings to make sure the printer and computer are set for the same wireless network profile and security settings.
For additional information, try the user's manual: http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
I hope this helps.
(I have generally preferred printing with a wired connection (USB) over using a wireless networks. I've always spent more time on printer problems that were directly linked to the network signal loss problems rather than printer issues.)
Dec 05, 2009 | HP Officejet J4680 InkJet Printer
We have a hp c4580 wireless printer and we are having problems with getting it to work. Can you please advice what to do. Bethany
Basically, you need to configure the HP C4580 printer with the same wireless settings of your network. Thus, you need to get the following information from your wireless router:
SSID or wireless network name
Type of Wireless Security
Wireless Security key/passphrase/password
To set those settings on the printer itself, you need to temporarily connect first your printer to the computer through USB. Then run the HP Printer Setup CD. It'll ask for you to install the required software then it'll ask for you to configure the printer on a wireless network. From then on, you will need to input the wireless settings that you got from your router.
Oct 12, 2009 | HP Photosmart C4580 All-in-One InkJet...
Blue wireless light will not comw on
Ensure printer is off - remove all software connected to the printer - switch computer off and back on - reload software - reconnect -
If still does not work we have something else conflicting with the printer. Of course you also need a wireless network enabled with ur computer for it to work...
Jul 30, 2009 | Office Equipment & Supplies
How to hook up this printer wireless to my main computer
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Feb 19, 2009 | HP OfficeJet 7410 All-In-One InkJet...
21 people viewed this question
k24674
