Question about Furniture
How to assemble? Screws and bolts, picture instructions unclear
893301WP
  • bogle_dee
    bogle_dee Jan 17, 2013
    Close the question, I got it figured out.
Assembly instructions
The brand would be helpful.
A Note: When you are assembling the bicycle be sure you tighten the steering-head and the handlebar screws and bolts properly.
Loose parts in this location is one of the prime causes of wrecks.
Dec 19, 2015 | Cycling
Hello, The passenger's side sliding door on a 2004 Kia Sedona minivan, does not close correctly, unless you push really ******* the door to help it close. I believe the latch needs to be cleaned and...
Kia doesn't publish instructions for servicing JUST the latch assembly for the sliding door. They only have instructions for disassembling the ENTIRE door.
Basicly, this is what you need to do.
Remove the screws and the door finish panel. Part of it simply "clips" into place. Make sure all of the screws are removed before pulling on the panel to get the clips to let go. You will have to be inside the vehicle with the door closed to access some of the screws. The others can be accessed with the door partially open. The door will have to be open to get to the screws at the bottom of the door.
Remove 3 bolts securing the inner door handle.
Carefully peel the door screen (plastic film) from the door.
There should be 3 bolts securing the latch assembly to the door.
Release the clips securing the outer door handle linkage to the latch assembly.
Remove the latch assembly.
Reverse procedure to install.
NOTE: There is also a Technical Service Bulletin (TSB) published by Kia that addresses sliding doors that are hard to open or close. It covers all the ADJUSTMENTS on the door that can cause these types of problems. The bulletin itself has lots of pictures and instructions about how to check for the actual CAUSE of the symptom and how to make adjustments to correct it. It is too large to post a copy here. You may try going by your Kia dealer to see if they will print a copy for you. If not, you can access the information by subscribing to AllData DIY for a small fee. (around $27/year)
It is Bulletin Number TT820405-001
Sep 05, 2011 | 2004 Kia Sedona
How to replace oil pan gasket
1994-96 VEHICLES
( see Figures 6 and 7 / click image for zoom )
Fig. 6: Oil pan mounting bolt locations-1996 3.1L engine shown
Fig. 7: Oil pan sealant application points-1996 3.1L engine shown
  1. Disconnect the negative battery cable.
It may be necessary to remove the hood, with the help of an assistant, for access.
  1. Remove the engine mount strut and A/C compressor (if equipped) and the engine mount strut bracket assemblies.
  2. Remove the electric cooling fan assemblies. -28467 and J 26462, or equivalent.
  3. Raise and safely support the vehicle. Drain the engine oil.
  4. Remove the front exhaust manifold pipe.
  5. Remove the intermediate shaft bolt/screw.
  6. Remove the oil level sensor.
  7. Remove the engine splash shield.
  8. Suitable support the drivetrain and front suspension with jack stands.
  9. Remove the transaxle mount side frame retaining nuts from the drivetrain and suspension frame assembly.
  10. Remove the engine mount side frame nuts from the drivetrain and suspension frame assembly.
  11. Unfasten the rear drivetrain and front suspension frame bolts/screws.
  12. If equipped, remove the lower drivetrain and front suspension frame bolts/screws.
  13. Remove the engine mount assembly.
  14. Remove the flywheel inspection cover.
  15. Remove the starter.
  16. Disconnect the transaxle mount assembly from the oil pan.
  17. Unfasten the side bolts and screws and the retaining bolts and screws, then remove the oil pan. Remove and discard the oil pan gasket.
To install:
  1. Clean the gasket mating surfaces.
  2. Apply a small amount of sealer on either side of the rear main bearing cap, where the seal surface on the cap meets the cylinder block. Install a new gasket on the oil pan.
  3. Position the oil pan and secure with the retaining bolts and screws. Tighten the retaining bolts and screws to 18 ft. lbs. (25 Nm) and the side bolts/screws using tool J 39505 or equivalent.
  4. Fasten the transaxle mount assembly to the oil pan.
  5. Install the starter motor.
  6. Install the flywheel inspection cover.
  7. Install the engine mount assembly.
  8. Carefully raise the drivetrain and front suspension assembly. Install the rear drivetrain and front suspension frame bolts/screws.
  9. Fasten the engine mount frame side nuts to the drivetrain and front suspension frame assembly. Install the transaxle mount frame side nuts to the drivetrain and suspension frame assembly.
  10. Remove the jackstands from the drivetrain and front suspension frame assembly.
  11. Install the engine splash shield and the oil level sensor.
  12. Install the intermediate steering shaft bolt/screw. Connect the front exhaust manifold pipe.
  13. Carefully lower the vehicle.
  14. Remove the engine support tools.
  15. Install the electric cooling fan assemblies.
  16. Install the engine mount strut and A/C compressor, bracket and the engine mount strut bracket.
  17. If removed, install the hood assembly.
  18. Fill the crankcase to the correct level. Connect the negative battery cable. Run the engine to normal operating temperature and check for leaks.
Hope this helps (remember to rate this answer).
Jun 04, 2011 | 1994 Oldsmobile Cutlass Supreme
The left backup lamp on my 95 cadillac deville is broken. Not the bulbs, they appear to be fine. The part that is broken is the glass or plastic part that covers the bulbs. I could use some step by step...
On the older models Devilles there should be torx bit screws one on the top and one on the bottom .Once you remove the screws gently wiggle the bezel loose and remove.Now remove the lamp assembly and remove socket assemblies.If there not screwed from the outside there bolted from the inside off the trunk.If there in the trunk move the corner covering in the trunk corners.There you will see the bolts that hold the lamp assembly in place remove the bolts and the lamp assembly will come out.
Feb 12, 2011 | Cadillac DeVille Cars & Trucks
I cant figure out how to install the handlebar. The owners manual is beyond confusing.
Go to my tips and tricks page. There are links to Huffy's website with on-line assembly instructions and detailed owners manuals.
The handlebars like in this picture attach to a stem (turkey neck shaped thing). There should be an end with a loop and an end with a shaft. The loop end clamps around the handlebar bottom. Just tighten the screw/ screws. The shaft end will have a long bolt and a wedge. The wedge has to be loose but attached to the long bolt. Insert into the hole in the frame, past the limit line and tighten the bolt. Thats it.
Dec 15, 2010 | Huffy Pro Thunder 12 Boys' Bicycle
Assembling 16" princess bike.
there is a wedge shaped nut and a long bolt that goes thru the top of the handlebars
found a picture for you
http://www.bikewebsite.com/stemwedge.jpg
the small piece in the middle goes on the bottom of the bolt so when you tighten it, it makes a wedge and holds everything in place
Dec 03, 2010 | Cycling
I have lost the screws, bolts and guides for a Christina cotbed
You can call Products America at 800-205-9642 or 800-772-1041. We offer a wide verity of hardware and instructions for many cribs.
Apr 13, 2010 | Cosatto Christina Crib
Furniture Logo
122 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
