Question about Lands Phones
BT Aura 1500 Quad telephone - calls list freezing
Calls list keeps freezing. Should hold the last 50 incall numbers then revolve keeping the last 50 incalls in the list. Recent freezes at 32, 34 and 41 incalls. To resume I have to delete all numbers and reset handset - I have then obviously lost all details of incalls.
  • Jane S May 02, 2013
    I have the same problem. Does anyone know a solution?
    New Friend:
BT gave me solution, which (so far) seems to work:
Reset the software of the telephone to default settings...
On any handset - 1. Press 'menu' 2. Scroll to 'settings' & press 'ok' 3. Scroll to 'base' & press 'ok' 4. Scroll to 'reset base' & press 'ok' 5. 'System PIN' will be displayed - enter '0000' (unless you have altered the default pin number) 6. Press 'ok' 7. Press 'yes' 8. Switch the main base station off at the power & remove the batteries from all handsets for approximately 30 minutes .
This didn't reset my address book (thank goodness) but did reset some other settings, such as time/date, OGM, group ringtones etc.
Posted on May 13, 2013
  • 3 Answers
SOURCE: Clear missed calls message
You can try this, it worked for us.
Press the key that says CID (Caller ID) to view every missed called telephone number. They disappeared, but we had to do each handset. Hope that works for you.
Posted on Mar 12, 2009
SOURCE: Panasonic KX-TGA711E (4 handsets) cordless phone no dialling tone
I unplugged the phone and then plugged it back in!
Posted on Feb 15, 2009
SOURCE: BT Studio 3500, Base station,
bt studio 3500 says memory full do not have 1571 how do I clear answer machine
Posted on Aug 21, 2009
SOURCE: base unit on bt synergy 3505 keeps beeping and
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Posted on Apr 05, 2010
SOURCE: Instructions for setting BT Freelance XC1500 quad telephone
i have BTFreelanceXC1500 PHONE I DONN HAVVE DDAIL TONE IN MY PHONE PLZ GIIVE SOLUTION
Posted on Jun 13, 2011
My Dect 3135 handset is flashing and shows New CID 1. How do I get rid of this and stop it flashing?
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls.
The phone saves the information for the last 50 received calls to the CID list.
The NEW icon marks any calls received since the last time you checked the list.
To open the CID list press CID.
Highlight a number and press MENU/SELECT.
The options:
Delete an entry - this will erase the number from the list.
Store Into PB - this will add the number to the phonebook.
Delete All - will erase all numbers from the list.
Jan 04, 2018 | Dect Lands Phones
Change the display name?
Administering a 1400 Series Digital Deskphone
Perform the following steps for each 1400 Series Digital Deskphone:
1. Log into the Avaya Aura Communication Manager administration interface.
2. Perform one of the following steps:
? If you are adding a new extension and want to assign a specific extension number, use
the add station nnnn command, where nnnn is the new extension you want to assign.
? If you are adding a new extension and want to assign the next available extension
number, use the add station next command.
? If you are installing the 1400 Series Digital Deskphone at an existing extension, use the
change station nnnn command, where nnnn is the existing extension you want to
modify.
The Station screen appears.
3. Perform one of the following steps:
? If you are administering a 1408 telephone, type 2410 in the Type field.
? If you are administering a 1416 telephone, type 2420 in the Type field.
4. In the Port field, type the port address.
5. In the Name field, type the name to associate with this telephone. Administering 1400 Series Digital Deskphones
20 Avaya 1400 Series Digital Deskphones Installation and Maintenance Guide
6. Configure the remaining fields on the Station screen pages. Keep in mind the following
information:
? If you are administering a 1408 telephone, the first eight call appearance/feature buttons
displayed on the Station screen are administered on the 1408 telephone. (Since the 1408
telephone is aliased as a 2410 telephone, the Station screen displays 10 call
appearance/feature buttons.) The remaining buttons displayed on the Station screen are
not administered.
? If you are administering a 1416 telephone, the first 16 call appearance/feature buttons
displayed on the Station screen are administered on the 1416 telephone. (Since the 1416
telephone is aliased as a 2420 telephone, the Station screen displays 20 call
not administered.
? If you are administering a 1416 telephone with a DBM32 Button module, the first 16 call
appearance/feature buttons displayed on the Station screen are administered on the
1416 telephone. The remaining eight call appearance/feature buttons displayed on the
Station screen are administered on the first eight buttons of the DBM32 Button module.
The 24 buttons of the EU24 expansion module displayed on the Station screen are
administered for the remaining 24 buttons of the DBM32 Button module.
For more information about administration and features, see:
- Administering Avaya Aura™ Communication Manager, Document Number 03-300509
- Avaya Aura™ Communication Manager Feature Description and Implementation,
Document Number 555-245-205
- Avaya Aura™ Communication Manager Screen Reference, Document Number
03-602878
7. When finished administering this extension, save your changes.
Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Dec 19, 2014 | Avaya Ip Office 1416 Digital Deskphone -...
Bt Aura
Here is the manual for the phone.
http://reviews.telephonesonline.co.uk/user-guides/BT-Aura-1500-user-guide.pdf
Is the answering machine grabing the call before you do? If so, follow the procedure to change the answer delay on page 54.
Jun 13, 2014 | Cell Phones
Caller display doesn't work
From the BT website...
"If you are using your phone on a broadband line make sure you fit an ADSL microfilter between the telephone line cord and the telephone socket."
I'm guessing you have one on the landline, probably next to the router but not the handset base :-)
Why is my Caller Display not working Help BT com Help
Apr 23, 2014 | Lands Phones
How to trace caller numbers on my BT telephone?
Dial *69 and that should give you the last caller, some phone company's will charge you for this service...
Feb 14, 2014 | BT Hudson Plus 1500 Trio Dect Cordless...
I've got death calls and I would like to change my number
go to the provider explain the situation the will change your number an can help trace the calls
Oct 06, 2013 | Spracht AURA CP20161 Landline Telephone
My bt decor 2500 the red light keeps flashing
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. If you're a BT customer then see page 17 of this manual. Otherwise please contact your telephone company for instructions on accessing their voicemail system.
Dec 12, 2012 | Lands Phones
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
My base keeps flashing but there are no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 16, 2012 | Lands Phones
Bt big button 1571 light keeps flashing but no messages
You're subscribed to a voicemail system provided by your telephone company that takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
May 13, 2012 | Lands Phones
Lands Phones Logo
1,105 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
