Question about Sony PlayStation® 3 (60 GB) Console
Replace component ps3 - Sony PlayStation® 3 (60 GB) Console
    New Friend:
  • 36 Answers
Just swap out cable for known good PS3 Component Video Cable.
Posted on Jan 16, 2013
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
I cant hook up my ps3 what cables will i need
hi,
You can use the VGA input for connecting the PS3. for that you need D-sub to HDTV/Component cable. Connect the vga sid to the projector and the component RCA side to your PS3. Your PS3 have the component video out.
ok
Aug 08, 2011 | Dell 1201MP Projector
My playstation 3 will not play in 1080p. It used to work, but when we switched cables, it wont work in HD.
When you switched cables, you mean you changed the cord running from the PS3 to the TV? HD content requires an HDMI connection from the PS3 to the TV. It is possible that when you changed cables, you replaced the PS3's HDMI cable with Component Cables which can only deliver in Standard Definition and not in High Definition (720p, 1080i and 1080p).
HDMI:
http://www.playstation3hdmicable.com/images/hdmi2.jpg
Component: http://www.componentcable.net/images/Component%20Cable%20PS3.jpg
Apr 29, 2011 | Sony Playstation 3 (PS3) Console
AHH
THIS CAN BE SOLVED IF YOUR PS3 IS OUT OF WARRANTY
The yellow flashing dot of death does normally mean that your PS3 is Dead but there is a way to fix it
My PS3 would not start and the indication light just flashed between yellow and red
Your options are: New PS3 £250, PS3 from Sony second hand £150 or £5 fix
1. Undo the screw below the warranty sticker in bottom of PS3
2. Slide the lid of
3. Remove all bolts
4. Remove all main components until the mother board is free from the unit
5. Remove the thermal gel on the back of the 2 main chips to the heat sinks
6. Clean any excess dust by blowing away do not use and dusters or leky equipment
7. Level up the m board and heat over all the board with a heat gun, needs to be really hot to melt the solder but not damage the board or components
8. Allow to cool and turn over repeat the above
9. Buy some thermal gel online and replace the gel removed of the chips using a credit card
10. Once cool after 15 to 20 mins replace all the components and PS3 Lid
11. Run a fan test on your ps3 (turn of at the back hold down the eject disk button and turn back on keeping the eject disc button held down until fan starts)
12. Turn you ps3 on and bam your back on COD or FIFA (add wadhapa)
Hope this is of some help but this is only recommended if your PS3 is out of warranty and you are not sending it back for a Second hand Sony one
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Ps3?
Check the couplings at either end of the cable. Sometimes these will loosen and can cause a lack of signal strength.
but its probably not the cable, its probably the ps3. HDMI cables don't really break because they are just wires, they don't have moving parts. Try connecting your PS3 to your TV with the regular cable red, white, and yellow connectors that you got when you bough the PS3. If the PS3 doesn't work with the original red, white, and yellow connectors then you know its the PS3. If the PS3 does work fine, you know its either the HDMI cable (still unlikely) or the HDMI connection on your TV or PS3 (more likely
Oct 12, 2008 | Sony Playstation 3 (PS3) Console
Hdmi cnnection ps3 to lgpx5
check the connection on the tv and check the ps3 one could be faulty
Jan 12, 2008 | LG 42PX5D 42 in. Plasma HDTV
Sony PlayStation® 3 (60 GB) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
