Question about Hoover Washing Machines
Hoover six express 1250 waching machine fills with water then does three fast spins and then stops
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 10865 Answers
SOURCE: 2320l hoover washing machine wont spin fast to dain all water ...on any program ...all other things ok ...can hear grinding noise when washing ..dont use machine at moment ..like metal rubbing:)
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 23, 2009
  • 4088 Answers
SOURCE: top loader hoover 600mb automatic washing machine
If this machine has a motor that uses brushes, check them for damage, wear, or weak/distorted springs.
Posted on Oct 20, 2009
  • 8 Answers
SOURCE: SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Posted on Dec 14, 2009
Hoover 600MB not spinning. Help please
NOTE: A 600 is not a fast spinner. towles and jeans etc do not come out very dry.
Helpful information prior to diagnose
Have you checked to see if the pump filter is blocked so that all the water can drain away.
Does the machine just stop with all it's water still in it.
Does the machine finish it's cycle.
Does all the water pump out, do you hear a sucking noise (means no water left) or a humming noise( means pump jammed)
Oct 01, 2014 | Washing Machines
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Hi i have hitachi SF-110CJ waching machine how can i cotrol the water temperature before starting the waching process
i have an error code f9 and washing machine stop spinning and dont turn , how can i fix it and where can I buy spar parts , i am from lebanon , west bekaa
Jan 19, 2010 | LWScientific LW Scientific Variable-Temp...
Six express hoover washing machine
I fixed it, allright, by returning the washing machine back to the store. Thanks anyway.
Apr 28, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
Hoover washing machine top load, model 550m.5.5kg
May 04, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
